when I went to pull my turbos off the first time, they were seized as buggery. Was really hard to crack them off.
I ran a tap over the threads and then put a dab of graphite-impregnated anti-seize on them. Then tightened them up the best I could.
5,000 k's later I had to pull them off to do my rb30 conversion. They still were clamped on nicely, but way easier to crack and wind off.
Where does everyone get the stainless studs from?
I get mine here, not sure what the thread pitch is on the RB's though, is it 1.5mm or 1.25?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200356383346&ssPageName=STRK:MEWAX:IT#ht_830wt_1139
After mine were a bitch to get off the 1st time I have the whole shebang a coat of WD40. (yes it burns off after 10mins). It's been off a few times and swapped turbo since and no problems - also no nuts coming loose either and they aren't stupidly tight either.
i have had problems a couple of time with stainless steel binding. its a f**ker when it does.
i dont bother using SS these days. i find high tensile bolt/stud in right size for what im doing and coat it with Caterpillar antiseize paste which is basically a copper paste. its not cheap buts its free for me and and amazing product.
deals with high temperatures extreamly well.
anything from caterpillar usually is great gear. on a side note, i use caterpillar gear oils in my box and diff in my track car.
Are you changing the turbo studs too? The 4 which hold the turbo on? If so what length and pitch are the standard ones? I need 4 new ones. My old manifold bolts looked like steel stud copper nut. Piece of piss to take both out after 30thou driving. New car has stock shit so I don't plan to ever take the manifold off lol. Need to replace the turbo ones as new turbo is going on. I've got some studs suitable but far too long and I really don't want to be here cutting away...
Lol actually I dont work for caterpillar lol. I work for a company called consolidated facilitations. Im an electrician by trade. My old man is a deisel fitter by trade and territory manager for caterpillar. Got a few mates who work in service for cat or in the mines doing break down work on cat gear so getting their products is not a hassel lets just say lol.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
