Hi I have got around the $1000 dollar mark to spend on buying and install. I can buy an exedy heavy duty clutch kit for 500 and fitted for 450. I might buy a néw pressure plate also.
Clutch kits usually come with a contact plate, pressure plate and thrust bearing. Don't let your budget decide your clutch, let your intended purpose and power output decide it. Exedy cushion button is a good clutch for that price range, but it may be overkill for the power output, or it may not be sufficient for what you need.
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5783749
A Exedy cushion button should last for ages at those power levels as long as you dont slip the clutch to much or do lots of burnouts/ high revving launches. If you are planning on doing some launches i would suggest the same clutch but not cusioned. It can take huge amounts of abuse but is more of a track orientatated clutch because of the heavy peddle and quick take up.
Of course if your budget is more then $500 theres definetley better clutches that are both stronger and easier to drive, have a more effortless peddle. Depends what you wanna spend or what power level you want in the future.
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5792328
Contact these guys for a clutch alignment tool http://www.directclu...ervices.com.au/ paid like 20 bucks i think for mine
May also want a torque wrench and loctite if ur goin to do it properly
Legend! I was looking for this tool. Did a search on the forum for this and your post came up. Dropped them an email and awaiting their reply.
Thanks heaps for this link!
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5806192
