Hi I have got around the $1000 dollar mark to spend on buying and install. I can buy an exedy heavy duty clutch kit for 500 and fitted for 450. I might buy a néw pressure plate also.
Clutch kits usually come with a contact plate, pressure plate and thrust bearing. Don't let your budget decide your clutch, let your intended purpose and power output decide it. Exedy cushion button is a good clutch for that price range, but it may be overkill for the power output, or it may not be sufficient for what you need.
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5783749
A Exedy cushion button should last for ages at those power levels as long as you dont slip the clutch to much or do lots of burnouts/ high revving launches. If you are planning on doing some launches i would suggest the same clutch but not cusioned. It can take huge amounts of abuse but is more of a track orientatated clutch because of the heavy peddle and quick take up.
Of course if your budget is more then $500 theres definetley better clutches that are both stronger and easier to drive, have a more effortless peddle. Depends what you wanna spend or what power level you want in the future.
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5792328
Contact these guys for a clutch alignment tool http://www.directclu...ervices.com.au/ paid like 20 bucks i think for mine
May also want a torque wrench and loctite if ur goin to do it properly
Legend! I was looking for this tool. Did a search on the forum for this and your post came up. Dropped them an email and awaiting their reply.
Thanks heaps for this link!
https://www.sau.com.au/forums/topic/362066-clutch/#findComment-5806192
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
