Firstly, I know there has been discussion about this in the past and ive read a number of threads but seeking input and opinions from those that have done it or seen it first hand coz im sitting on the fence here...
Heres the basics of my situation -
Cars a 32 GTR, before I bought it, made 270rwkw on 1 bar with -7s, PFC, Forged motor, Tomei Fuel pump, stock Injectors/AFMs and an SX Pressure Reg.
Ive since added some small Tomei cams and am now ready for a tune and somewhere around 18psi.
I bought some Siemens 740cc Injectors ages ago (can sell easy enough) but am wondering whether is it really worth doing Injectors and Z32 AFMs with these turbos?
Is is realistic and more importantly safe enough to squeeze the stock injectors and AFMs to the limits of the -7s? My tuner mentioned he can 'tune around' the stock AFMs to an extent...
I figure with the cams and 18psi it MIGHT make 300rwkw ish?
What would you do?...Im at a point where im trying not to spend on it so if I can retain stock AFMs and Injectors with the SX reg and make close enough to 300rwkw i'd prefer to!
Thoughts?
Cheers.
I made 340rwkw with stock injectors/AFMs
Obviously there was a fair bit more rail pressure, and tuned well past the AFM's limits...
The car came like that, so for safetys sake i put in 700's
300 wont be a problem though. One thing would be get the injectors flow tested/cleaned before doing it.
i think it comes down to how reliable you want your car. if your tuner can tune around the AFM's thats fine - lots do. but on stock injectors you'd be running close to, if not on 100% duty cycle. you would be leaving a very small margin of error so things are more likely to go wrong.
personally, 85-90% duty cycle is the most i'd go at peak boost/power. you'd be well over that, most of your usable power will be in the 90-100% duty cycle range.
IMO you could make a little more than 270 with that combo as is. First thing to check is the exhaust.
AFMs you can tune past with an element of risk, injectors are risky near 100% and fatal over 100%.
Also clean injectors flow far more than dirty ones. There was a recent thread showing injector that were flowing evenly, but flowed 20% more after they were cleaned. So, as well as rail pressure and AFR, injector cleanliness will determine how far you can get on the stockers. If they're leaking already its a no-brainer - replace them.
Cool, so you kept stocko AFMs @340rwkw Nismoid?
And MrStab, what Injectors/AFMs are you using to make 305rwkw? Stockers?
The existing Injectors arent leaking and im pretty sure theres a receipt in the pile that came with the car for having them cleaned/flowed but would do again to be safe...
But based on above, I think i'll whack the 740s I have in there and work with the stock AFMs...seems theyre 'less' of a safety issue than the injectors, as long as tuner is capable enough of working around them.
Cheers.
Edited by NSNPWR
Cheers.
Yes they were stock.
I did put Nismos/injectors in after i purchased it.
Car ran fine like that for 2 years however under previous owner.
Injectors are seimens 550's, but they were originally bought to replace leaking stockers before i got the -7s. AFMs are stock, so I assume they're out of resolution at full torque. In this case the tune should be extra rich in the map areas where AFMs are maxed so the engine wont lean out on a cold day (cold air = more air mass, which means it also needs more fuel, but the ECU has no way of knowing that). When the AFMs are maxed the ECU is just estimating fuel delivery based on RPM. I'm probably going to get nismo AFMs before i push it to 320-330.
The tuner should be allowing for and checking this on the dyno then, yeah?
You think the -7s will go 320-330? You mentioned exhaust, im running ceramic coated HKS split dumps into an unknown brand front pipe, into a big metal cat into a 3" pipe with one muffler right up the back...again, for the outlay, is a 3.5 worth the $$$? A few years ago ive had not been worried and just spent the $$$ but Mortgages etc change priorities!...
Edited by NSNPWR
Yeah, but it cant hurt to specifically ask him to do it.
I think 330 is possible given the current power and boost level, but I wont know until I try. I probably need a stronger clutch, and if i'm taking the gearbox out I should do something about the noisy input shaft bearing.... so i'm putting it off for a while.
Re exhaust, get the tuner to drop it at the front pipe to see if its an issue or not.
Cheers. Not exactly sure of clutch in mine, some cushion button thing with a billet flywheel according to receipt...hopefully holds up.
Should a full weight 32 GTR trap around 120mph with 300rwkw and a good launch? Or more? I'd like to think it would do that easy...
Buy a pair of rb20 afm's- they're direct plug in into the stock loom and will give you enough resolution for 380-400rwkw as well as being cheap. They're the same size as Z32's just half the price and no need to change the plugs.
You have injectors already... so why take the chance? Or sell them/swap them for smaller 550's.
I find it a little silly to take the chance at wrecking an engine for the sake of lazyness?
Cheers
Justin
Lol @ cheapskate...Running PFC, thanks for the tip mate, 20/25 AFMs arent exactly in abundance from browsing the forums?...
Like I said, im trying not to spend on it, nothing to do with being a cheapskate, have burnt plenty of cash on this and previous cars.
Should be plenty around form people upgrading to Z32, Link/Vipec etc.
Plenty in NZ - have a look thruigh these ( I could probably get you a couple or three cheap and post them to you if you can't buy direct):
http://www.trademe.c...rch_suggested=0
300 for a pair from any import parts wreckers???
Just remember they are still 2nd hand.
You could burn $300 on a 2nd hand set and then have them die on you a week later :/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
