Ok Im not a fan of anything rice and spending $150 on a piece of sheet alloy with a $90 degree bend in it and a few holes wasnt my idea of fun. So after looking on google there were plenty of DIY out there for different cars. I got my inspiration from a few pics of them for the 34 GTR (can get them for your specific model of car if you wish) and to give me a general idea of the shape etc etc. My finished product is by no means perfect but for a fun cheap DIY im very happy with the results.
Took me a few days of tinkering here and there. Cost me $15 as i had the paint at home.
tools required were:
Files (flat and round)
10mm spanner
flat tip screwdriver (for popping out a few clips)
drill
angle grinder or other cutting device (plasma cutter etc)
bench grinder/snader if possible (you can just use the files)
Materials:
Cardboard
sheet of alloy
Paint if required
First of all was the cardboard model:
Next I bought a piece of alloy, cost me $15 and traced the pattern:
I used the workshop at work and first cut the pattern with all the holes out. I was lucky as we have a plasma cutter at work, sounds fancy but is only good as you are at making a straight cut and requires a fair bit of sanding in the bench grinder/sander etc.
Once all parts were cut and drilled I then made the bend as required.
Once its all cut you will most likely need to make adjustments to get it to fit, cardboard just doesnt represent alloy all that well for the amateur like myself. Metal smith=no worries.
And it resembled the following:
Due to the tool marks and clamp marks I painted mine black (plus i prefer it on the white car):
Before installation:
And fitted:
https://www.sau.com.au/forums/topic/362521-i-made-my-own-cooling-plate/
does this actually do anything?
Yes, it forces all air coming through the grille to go through the radiator, rather than some going over the top of the radiator support; bypassing the radiator completely. Air will always take the path of least resistance
I've often wondered if it would be beneficial to duct the intake snorkel down through the cooling plate to pick up some of that cool air too.
Edited by Daleo
i was just about to attempt this exact same thing for my 34gtt. only ones i can find for a gtt are 150-180+....and they are not worth that much coin. ill post pics up soon as i bash one out. great job mate! looks killer. btw, how did you go about the 90deg bend? and what thickness plate did you go for?
thanks mate
LOl thanks guys,
I Used 1.5mm alloy, its a good thickness, easy enough to work with.
For the 90 degree bend i just marked where i wanted the bend to be, then placed it on the bench with the marks for the bend on the edge of the table and hit the over hang with a hammer (I have a soft head hammer, so it didnt mark the metal). It required a few little love taps here and there once i started fitting to the car, but it come out straight.
THAT LOOKS AWESOME MATE!!!
do have a question tho.. i thought that air for the air filter came from there? i might be completely wrong but im looking at doing somethin similar but addin an air duct in the plate directing some of the air to the original factory air duct..
Cheers
Herbie
The airbox snorkle will just suck air from wherever it can find it :) I think this will restrict some of the cooler air but i doubt it will have any effect.
BTW, looks fantastic! Quite keen to give it a crack on mine now
Cheers
Herbie
Thanks Mate
All the cooliong plates i was looking at like the ARC ones etc etc all run the same desgin i used. I figured if theres runs like that it cant be that bad for the cool air.
I gave it a crack as well, didn't even use a cardboard template.. just measured and drew on the ally.
Shitty camera phone pic at night but you get the idea. Have edged it with some split 4mm vaccum tube and will paint it black when I get a chance to grab some UHT Black.
Will also look at some "wings" to go down the sides between the cooler and radiator (have gutted aircon and mounted 2x thermo fans where the condenser used to be).
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
