  • 2 months later...
  • Replies 99
YESSSS!!! there sure is updates, pretty big ones at that, sorry i havnt had the chance to get on here to update the build! :(
Well i have sold the T04E turbo and in its place will be a Kinugawa TD06SL2 20G 10cm, i know i said that garrett was the only way to go, but looking at the dyno results from others it seemed hard to justify paying almost double for a turbo that gets relatively similar results.
I have also taken out the short shifter and replaced it with a standard shifter.
Whilst the new turbo is going on i will be re fabricating a new stainless steel 3" exhaust system with twin pipes coming out the rear, should sound nice!!
enough chitter chatter, here are some pics for now.
P.S the exhaust system pictured is one i just finished welding up for an S15, im going to be doing mine similar to it.
This is how the engine bay looks currently:
Goodbye old turbo!!
short shifter Vs stock shifter
exhaust system i welded up for workshop one in carrara on the gold coast, highly recommend their workmanship towards all car mechanical servicing and rebuilds etc.
UPDATE:
So my new turbo arrived yesterday! only took 3 days! was pretty stoked so i started going at it right away, ill let the pics do the talking.
everyone takes photos fresh out of the box......right?
test fitted it onto the manifold, very tight fit but still fits none the less.
took all the exhaust stuff out so i can make a start on the water and oil lines, dump pipe etc.
Made up some braided lines from aeroflow
another pic of the braided line set up.
Also finished fabricating/welding the v band onto the dump pipe and test fitted everything. now i have to begin putting everything back together and get a dyno tune.
enjoy!
Hey mate curious as to why you took the shrt shifter out? Not strong enough to use on track/vulnerable or??
Can't believe the exhaust is 3 inch? Looks huge! I have one very similar on mine and let's say it's VERY loud haha :)
Love how this is developing mate.
Edited by gtsttrk
Thanks for the feedback mate, I took the short shifter out because it was getting a bit notchy. Standard shifters are awesome!
I got the turbo bolted back on to find that my old oil drainage is way different to before. So ill be going to make buy more fittings and make up a braided line for it.
Ah yeah nice bro! I was thinking of putting a short shifter into mine seeing they're pretty cheap, but yeah the standard shifter isn't that bad and I see a lot of people end up reverting back anyway. And apparently they aren't the best for tracks anyway.
Can't wait to keep reading this bro!
Little bit more of an update now, seen as though the rain is constant on the Gold Coast at the moment i thought it would be a great time to work on the car some more and try to get it done.
first off i modified the dump/front pipe to suit vband:
new heat wrap on the dump pipe.
Got the turbo in there, started hooking up the braided lines:
just clears the rocker cover
All i have to do now is buy the fluids for her, i am going to be switching from nulon fully synthetic oil to AMS oil fully synthetic, i will also be running BMW concentrate coolant and doing a amp/V test on my radiator to see if there is any current coming through.
Once all this is done i will start her up, hopefully all is well and i can go get a dyno tune. I am hoping for around 350-380hp on 18psi.
Hope you all enjoy the update.
Im also selling this custom surge tank i made up:
Make an offer if your interested :)
  • 1 month later...
  • 3 weeks later...
UPDATE!
not a good update, but still an update none the less. I had one job left to do on the car which was to apply thread sealant to a inlet manifold bolt that was leaking a bit of coolant, so i took the bolt out.....cleaned it, cleaned out the female thread on the head of old sealant as best i could, applied new sealant to bolt and as i was tightening the bolt up with a 1/4" ratchet i hear a loud CRACK................thought it may have been the ratchet slipping a tooth or something as the bolt wasnt tight at all......tighened the bolt up, let the sealant set for a while and put coolant in the system.....this is where i found out what the crack was....it cracked the female thread on the head....major FML situation...so i have started taking everything off to get the head off....
While the head is off i will be getting it serviced along with a new cometic gasket set and ARP head studs. Atleast ill be able to run more boost knowing i have a steel head gasket in there....anyway here are some pics.
cracked thread:
1 hour later:
also have exhaust manifold and all belts off now....hopefully the block is still good and the head wont need much work.
UPDATE:
This is now how the engine bay looks :(
5c7a3b87-a066-440a-ace2-3221b039444b_zps
dropped the head and intake manifold off to works engineering where he will be servicing the head and machining all surfaces.
Gates racing timing belt kit is on the way along with new ARP head studs and a COMETIC head kit.
bit more of an update, got all my parts and picked up the head fresh from being serviced, so happy with my cometic VRS kit and their MLS head gasket looks unreal!
anyway here are some pics!
will hopefully get it all back on the car in the next few days and then to get her on the dyno and hopefully pull some decent numbers!
  • 1 month later...
UPDATE:
So the car went off to the dyno a few saturdays ago, and as usual the only thing i didnt replace was what failed on me, the thermostat was stuck open and not getting hot enough to push power through, also my TPS was reading to low V and had to be modified so i could rotate it more to get the correct Voltage.
SO..... on sunday i put a genuine nissan thermostat in and modified the TPS mount so i could rotate it more, i set the TPS to .38V when car is on accessories only...seemed ok so i turned the key and more problems occured....the car is idling at 2,000RPM.... not sure why so i turned it off, replaced all vac lines and certain fittings...still made no difference....so i took the AAC valve off, cleaned it and went to put it back on when i found one of the mounting bolt threads were stripped.....could have been a problem with the high idle also ??? so i have to helicoil that tomorrow and put it all back together to see if it is still idling high..
if so..... does anyone know of a certain procedure that needs to be done when putting a TPS back on? such as foot to the floor (throttle completely open) etc??? any help would be appreciated.
for now, here are a few pics, also got a 200mm dildo shifter.
  • 1 month later...
UPDATE:
i had the car on the dyno a few saturdays ago, all tuned up with standard throttle body back on, new thermostat and TPS set up perfectly.
the car performed very well and im happy with 373HP at the rears on 17psi, i will be getting a new CAS in the next few weeks and putting it back on the dyno to squeeze a bit more out of it as my current CAS is playing up at about 6300 RPM to rev limiter, not a big deal by any means.
  • 7 months later...
  • 3 weeks later...
  • 5 months later...
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
