  • Replies 165
maybe it was this civic lol
... but unlikely. it was most propably a bog stock shitter that still knocked off an overweighted, underpowered atmo 34
My mate only showed me this the other day. I really want one of these for a daily / sleeper would be insane the sound :) would scare quite a few people
" whats she running only a little 4 cylinder " lol
