It's funny that the only cars mentioned to have cracked rear frames didn't have tow bars
Your comment makes no sence as the bars are only rated for 70kg or so down on the ball, and the pulling force is not directly linked to the sub frame.
If the trailer trailer/ tow ball height combination is level and the trailer is loaded wIth it's weight over the axel then there will be no issues.
Go nuts then. Doesn't mean I'm going to do it with my car. Yes, I know how tow balls are rated.
Look, I'm not trying to be a prick. I just don't think its an awesome idea on a car that wasn't designed for it. We know the subframe cracks, we know overloading causes it.
If you plan to tow big and long, please make sure you have an external tranny cooler, and you have seen to the turbo banjo, and the turbo is in tip top condition. I know another Stagea (C34) drivers been through 3 china turbos, probably because he tows a car with it! Maybe even get a radiator upgrade.
That's not entirely true, but it's not my place to identify the cars. Also, it seems more prevalent in vehicles with HICAS for some reason.
I have a tow bar on mine (the Fast Fit towbar was designed on my car); and frankly, I believe they just aren't suited to towing something the weight of a car. I put a tonne in my trailer over relatively short distances (100km max), but I wouldn't want to do any more than that. I only end up with around 30-40kg on the ball in my "worst case scenario". I haven't had any cracking issues.
There is no real chassis structure in the rear of the car that is suited to the forces you'll be putting through the rear sheetmetal.
All you are really using is the rear bar reo mounts; and this is a structure designed for compressive forces(think rear impact), not to be held in tension. The legs that go under the car are only there to stop you applying torsion (leverage) to the reo mounts; not to carry any great load.
As Alex said; go for your life if that's what you want to do, but just be aware. There are many other cars better suited to towing heavy loads; and have 2000+kg rated factory Hayman Reese towbars.
Edited by Daleo
  • 3 months later...
Hi all, was searching about sub frame cracking, as my stagea ARX has it on both sides of the upper subframe. I was wondering if there was any evidence for what the cause was - I baby mine pretty well and dont dump it off the line... BUT i moved house earlier in the year and loaded heaps of gear in it - AMAZING HOW MUCH YOU CAN FIT!!! So ..... That could be the main reason ... damn. Well it sat pretty low a few times... I had to move a 3 car garage...
Now.. can someone tell me how difficult it was to remove and repair. I imagine a good TIG welder could fix it pretty easy. Has someone done it ? did you re-enforce it with a peice of al over the top of the crack? thanks
  • 1 year later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
