Hi guys,
I'm at the point where i need to know what turbo i'm going to bolt on, mixed opinions from so many, i dont want to spend more than what a t04z costs eg t51R
so i'm asking ... what large turbo for a price around the t04z's price range can i also get and what turbos are better than a t04z with price ranges around the same? im not chasing response as much because ill be running nos for that so shoot lets see what u guys think...
https://www.sau.com.au/forums/topic/363328-single-high-mount-decisions/
I think you need to at least tell us the car and current mods, desired goal and yeah
R33 GTR series 3, forged engine tomei oilpump sump baffles cam baffles etc just want a powerhouse turbo... power chasing 380-500awkw
Edited by v8tzr
The sound of a t51r coming onto boost is worth the extra money
Any unmuffled anti-surge turbo sound more or less like that. EFR9180 would sound similar but better spool and good for that power range.
First things first, the above mentioned turbos require some serious work. Beyond 400kw atw (and from a single) you will need the following:
External fuel pump, usually 2
Surge tank
lift pump
new fuel lines front to rear
braided fittings everywhere
a $2000 intercooler not including the pipes and thats provided you find one used
an external gate work half what the turbo is
a quality manifold worth almost as much as the turbo
head porting worth more than the turbo
Lets put it in lame-mans terms, $20,000 minimum.
You could however say, 400kw atw will be enough. Strap on some 2860-5s, use stock location parts that are all off the shelf, use ONE fuel pump and the standard lines, etc etc etc, no worries at all.
However you could be a bored mining engineer and/or a dealer of some sort OR maybe someone who thinks they can strap on a turbo and hey presto!
Heres some 2860-5 love:
You will get similar power results from a T04Z, but need to ditch your standard manifolds ETC and add a fair bit of cost. But it will be sexy etc. The T04Z will be missing some spool. You could also punt unknown grounds on one of those new EFR turbos, they apparently spool fast and make bulk power given lots of boost and alcohol based fuels.
GL
^ Mines GTR runs HKS GT2530s...
The Precision turbos are the ones that don't seem to do much without using ethanol or race gas, there are some decent EFR results on pump gas - even at conservative boost levels.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
