So you have seen the light and joining the "forklift" club :thumbsup:
It's not for the GTR... just the POS gts-t- It's got a Trust T67-25g now. The power delivery isn't nearly as savage as I remember your 33... memories lie! It has 40 odd more rwkw and several hundred kg lighter than when I was in the 33 all those years ago- but it just dosn't feel as fast???
I have many mate, located in launceston.
Daniel.
Any ideas on what it might cost to get a couple down south?
I have a couple or 3 in varies stages of pieces all good blocks and cranks ph 63834643
Are you north or south?
Cheers
Justin
Cheers
Justin
Dale (dbgtst) is up north.
Ahhh the old days when 245rwkw was fast. lol
I look back thinking I should have just been happy with how it was instead of wanting more power.
But the new setup should be interesting....
Sorry didn't get a chance to go for a drive out to the shed on the weekend. But I definitely have a complete set of stock S13 suspension :thumbsup:
Engine mounts are SR your after I'm taking it?
All good cobber Im not in a huge rush so when ever you get a chance.
Im just chasing up everything I need so when I start working on it again I can continue on with no/little interruptions thumbsup.gif
Cheers, I did spot that and sent him a PM but didn't hear back.
RB26 Custom Made JE pistons, 86mm bore, made specifically to use factory rings, world reknowned for being the best rings available. Brand new in packaging, comes with pins and spiral locks and a full set of new factory rings.... $1100
R34 GTR Tomei Type A Poncams, 260in 252ex 9.15mm lift, brand new in box, justjap want 1400, works in any rb just need to use R34 crank angle sensor. sell for $800
R34 GTR N1 block, split bore, needs one sleeve then better than new! $1000
R34 GTR 18" Wheel center caps, immaculate condition, set of 4 $120
SR20DET .2mm oversize factory pistons, brand new in boxes, retail over 300 each, with rings, sell the set cheap $500
SR20DET cast iron factory turbo manifold, as new low km hardly even been hot $120
1972 Triumph 2.5L PI (injected) complete car suit restoration, has engine and all running gear, two spare heads, two manual gearboxes, with one overdrive, all chrome trims immaculate, brand new door and Windscreen rubbers, shell is as it good as it gets, next to no rust, no damage. $1500 or offers, keen to move, need shed space.
Let me know!
Ok so I'm all sorted out for dirty 30 gear...
I did broked my clutch m/c though...
Anyone have a r33 gts-t clutch master cylinder???
i do , can't get to it until friday though, speaking of , has prizo given you those wheels yet??
WTB: std heat shields for rb20/25 turbo
and eoi my hks gt2530 , comes complete ready to bolt on (water/oil lines and hks dump) pm me
hey Toff... I'll call you next week about the m/c. Na havn't got the wheels yet- are they off the laurel?
Cheers
Justin
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
