Hey guys after speaking to Brad at boost today, turns out my safc wont help me as id hoped, so im just putting it out there that ill soon be looking for a pfc or some other decent piggyback/stand alone ecu,
so if you know of or have anything let me know & i can get back to you when it comes time
cheers
Get a z32 ecu (like $50) as it will run the vct or a rb20 ecu and get a rpm window switch to run the vct (it's what I do).
A board is around $400 ish
Install is around $100
Should be all set up for under $650
I like it for my set up.. 300+rwkw rb2530 with a T67
you need to add tune cost to that. i know that GT were $1100 base price for complete nistune job.
hmm now that is tempting, i thought they were around $1000-$1200 installed & tuned but $650 sounds much better
650 is only instaled. it wont run like that so you then have to instal it and tow it to a workshop then have them tune it wich will be min $300 so theres almost your 1100 for gt.
im pretty sure boost is cheaper than that but power fcs are cheap and they come with a base map and do all the things you need.
nistune is the cheapest way you will get around it but for the price and added benifits of a power fc it would have to be the next cheapest option.
if you find other cheaper ecus like link you will need to find a tuner that will be happy to tune with it. everyone tunes power fcs.
I'm happy with my Nistune =) very easy to figure out as far as tuning is concerned, and they come with base maps to suit all nissans so they run the same as the std ecu :) all up it was under 700 fitted but i have tuned it myself so saved a lot of money there.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
