you need to add tune cost to that. i know that GT were $1100 base price for complete nistune job.
650 is only instaled. it wont run like that so you then have to instal it and tow it to a workshop then have them tune it wich will be min $300 so theres almost your 1100 for gt.
im pretty sure boost is cheaper than that but power fcs are cheap and they come with a base map and do all the things you need.
nistune is the cheapest way you will get around it but for the price and added benifits of a power fc it would have to be the next cheapest option.
if you find other cheaper ecus like link you will need to find a tuner that will be happy to tune with it. everyone tunes power fcs.
If you plug in a pfc it won't run out of the box if your running bigger inj's or differnent afm etc. The nistune runs a stock map (same as pfc), so once installed it will run like a standard ecu... unless there is a wiring change for z32/rb20 ecu (pretty shure there isn't. just search it) for your application.
Whoever you get to install the nistune or tuner should be able to make the required changes for inj and afm etc to the ecu off the car, so you can drive the car in to get tuned.
But go with what your tuner is happy with..
If you're not a complete tard you should be able to setup your PFC or nistune to suit your injectors and AFM and limp it to the tuners. I wouldn't drive it to work for 2 weeks but...
also +1 go with what ever your tuner likes best, because at the end of the day, any ECU is only as good as it's tuner.
takes about 2 minutes to set it up to run. has z32 and vh41/q45 afm as a option, then set the injectors. if i can do it, your dog can do it.
and i drove my car for 2 weeks like this as my daily. nothing over 5k but still did it with no harm done. when i scaled the injectors, they "should" of been set to 50% but i left them at around 65% to be on the safe side. you can leave latency time as is to just get it from a to b
It's a very similar process to set up the nistune. Just as easy. :nyaanyaa:
Nistune is as easy as:
1: Receive
2: Plug in
3: Drive just like standard :)
And after that its all down to aftermarket bits/ tuning.
Yes... but there is some changes that need to be made in order to run larger injectors or afm.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
