anyone got some r33 gts rotors going cheap?
i've got some of the same size but they are 5 stud, so if you want to sell me your 33 gts rotors and they are in decent nick and cheap then i shall take them off your hands
I've got a pair here but they will most likely need machining as they've got a small lip on the outside edge
Have heaps more stuff than listed :)
Dave - 0409 631 092
Just a few things to get out of my shed, as usual have run out of space!
20V AE86 $6500 http://burnie-devonp...?AdId=360168336
1JZ S14 $18000 http://www.nissansil...em&item_id=4397
1JZ S13 $11000 http://burnie-devonp...?AdId=352702689
Rims for sale!
Work Meister S1 3 Piece 18x9.5 -3 pair $1600
Performance superlights, brand new pair with brand new Hiro Tyres 15x8-4 $600
14x7 ma61 pair with new tyres $250
15x8-10 performance challenger pair with 80% tyres $400
Cooling Shelf overflowing, gotta go!
AE86 52mm twin core alloy radiator new $220
RB20 52mm twin core alloy radiator new $220
Sr20 twin core custom alloy radiator, used $120
SR20 modifed Falcon Thermo Fans, as new $150
SR20, RB20, CA18 stock radiators $50 each
Used 600x300x60 intercooler $100
Earls Oil Cooler, -10 fittings, new in box, size of a4 page $400 (can do lines also)
Heaps more than I can think of at the moment, ask away!
Engines/Gearboxes/Mount Kits in stock, all great condition as usual
1jz manual package $3500
SR20 manual package (BYO TURBO) $2300
CA18 manual package
LS1 Silvia/Skyline/Cefiro Conversion Kit $2200
1JZ Silvia Mount Kits - $350
S13 Manual Conversion Kits $500
SR20 Gearboxes $500
Quick 180SX body sale need shed space again!
S13 or 180sx complete front conversion kit to S15 - $1100
180SX rear guards 25/30mm Origin Style good condition - $150
180SX Type X front bumpers - $250 each
180sx frp 50mm Origin slightly cracked wide rear guards - $50
180sx frp 40mm Origin front guards, drilled frr cable tie bumper mounts - $200
180sx standard tail light set (not type x) $150
Federal rsr semi slicks 70% 215/40/17 $250 pair
Federal rsr semi slicks brand new 215/40/17 $400 pair
Federal 595ss brand new 215 and 235/45/17 $250 pair
Federal 595ss brand new 235/40/18 $275 pair
Federal EVO brand new 195/50/15 $220 pair
And any other federal or kumho or no name cheapies also available too much to list of course :)
Dave - 0409 631 092
Edited by Dave.TAS
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
