40 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
That's not that amazing tbh. I've heard of people hitting around 4500-5000rpm in 4th gear at 170 in a bone stock car.
my friend reckons he took his mums excel to 220 or something on a freeway.. they take a fair beating.
I took mine to 180 when I was 17. Totally not worth it.
was just saying that NA skylines really lack in the performance aspect, even a crummy old hyandai excel has a top speed faster
  • Replies 58
180kmh @ roughly 5000rpm in 5th gear and struggling to get any more speed out of it. Did have the speed limit cut out on it too. Done on the track ofcourse
So it doesnt have a limiter ??
I know my 32 (auto) is limited to 180 and definetly wont go any higher then that.
Even at 180 it physically doesnt feel like it could get much higher then 200 (although a rb25de would have a bit more grunt then the shitty rb20de).
i got about 160kmh on 5000rpm gear 5, don't know if it would go any faster the car was vibrating lots
I did 170kmh twice... the car nearly fell to pieces when i was braking :rolleyes: I would try 200kmh on hwy with my RB25DE once i decided to suicide.
really only 170/180 kmh, fastest ive gone is 140 kmph Comforatbly in an AU falcon, easily coulld go over 200 imo.
I've gone past my speedo (180km/h) in my na 34, can't remember the rpm. Was a bit surprised thought it would be limited at 180.
what speed did you end up hitting?
you have to take into account error in the speedo unit. from my experience in multiple imports, generally the speed limiter kicks in at an indicated (approx) 190kmh. this is because they often factor in a few percentage over read so that the speedo reads faster than the actual speed so that you don't get booked so much (and because it is a legal requirement from what i gather)
All of the factory maps I have looked at have the speed limiter set to 178kmh, there will of course be a discrepency in speed between what the wheels are actually doing and what the speedo says, depending on tyre sizes and how lazy the speedo is.
exactly what i said.
i should also point out that when i had my 33 on the dyno it hit the limiter at 180kmh by the dyno speed reading, but it was past it on the gauge.
  • 2 months later...
I hit 170 in my ca20e equipped Nissan pintara, was pretty damn scary in fwd. I now have a N/A r34 and on a dyno run it went off the clock completely at 7400rpm. I had it at 150 at one stage on the road and the speedo needle was still going strong. I don't think it would have any problems getting 200.
im getting my flame suit ready, but i think all this chat about the max speed of an n/a skyline is just pointless ... you wouldnt buy an n/a skyline to go at speeds above 180km/h, thats how i think about it anyway...
getting to 150kmh is easy. getting past 180kmh is a lot harder.
and don't pay much attention to how fast a car speeds up on a dyno. for starters there is no aero drag and that is one of the biggest factors in top speed. that said, a natro skyline would do over 200kmh, but it will take a bit to get there
Yer i dont really get it either man... but saying that, with with speed limiter removed the RB25de will do over 200 but dont expect it to get there in any great hurry.
Its not about how fast you can go its about how fast you can get there. Hitting 200km/h in a DE, the turbo counterpart can probably hit 200, stop, then do it again in the same amount of time.
That said some dick I know has a Yaris, he used to do M4 driving at 180km/h, smooth as f**k lol.
  • 3 weeks later...
I've got where 190km/h would be on the speedo in the rb20e, but I tried again by just flooring it in 5th and as soon as I hit 180km/h the speed cut kicked in. Think it was because I reved it to 6800rpm in 4th the first time and I think thats past 180km/h then changed to 5th. Yes it's slow.
ive hit roughly around 190 as it reads on the speedo before the speedlimiter kicked in the the car just rapidly decelerated to around 160 even with my foot flat to the floor. 1st time i tried it, i thought i blew the engine lol
that won't make a scrap of difference as the ecu simply goes off the speed sensor. it doesn't know what gear you are in (and it doesn't care). my 180sx used to hit the speed limiter in 4th.
and to do that in a car with a rb20e, you must've had a good tail wind going down a steep hill, lol
I got an r33 GTS4 same stock engine Ive got no problem getting to 170 and then it just seems to crawl at snails pace up and ran out of road . . . errr track so slowed at 175. I think mines a fair bit weightier but I had always thought that would mean less accelaration and wouldnt affect top speed as much. I know its not alot to many people but ive always wanted to hit 200.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
