  • Replies 3.6k
Posted Images
Haha our old mate Ted180 .... times like this I wish I had taken up a mod position on HardTuned when offered .... but then again, policing that bunch of rabble would be a challenge :D
all the cheap and generic and even some of the jap ones fall into this category. but not all stainless mani's are junk. Mine's made from stainless steam pipe with 3mm wall thickness complete with merge collector and its strong as hell.
no doubt the wall thickness is what's saved you so far Simon.
Unfortunately, even with that sort of thickness, it's probably only a matter of time due to the constant stress on the metal during expansion and contraction (much higher rate of growth than cast).
Another reason why exhaust housings on turbos are all cast as opposed to S/S
It doesnt matter how thick it is, or how strong it is, the stainless turbo exhaust manifold is inferior for very basic reasons.
Stainless has a different material phase diagram that makes it more prone to cracking than an equivalent high nickel content iron. When you see OE manufacturers producing turbocharged engines with 304/316 stainless manifolds then you are onto something....until then....
The only Snap On tool I want is one of those cordless impact drills. And well, they're hugely expensive.
Nah, they're shit. We've killed nearly all ours at work, batteries dont like being recharged more than a few times :/
Hilti impact drivers are the way to go :)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
