  • Replies 3.6k
Posted Images
guys we serouisly need to do something about all these defects and stuff....
i passed regency like this...
http://www.youtube.c...h?v=izvw5R4Jua8
i nearly spun it coming around a corner.. the day i was getting inspected
the shocks were unstable and shook the wheels and hopped all over the place
look at this convo between Luke and "siba33"
http://www.skylinesa.../page__st__4420
officer Neil ..... ran a red light to stop siba just to defect him
write a letter
Aah well on the lighter side me and pistol pete are stuck in Port pirie meant to be coming back from work, but its a bit of a walk back to adelaide.... Blown a piston in the 32..
comiserations matty :(
good excuse to build it tough though :yes:
tried to call u back a second ago no service.
sorry to hear!
hey mate,
if you've got any parts that you need to sell for a good price to help fund this build let me know.
also if you're after 350kw and want the car looking std under the hood, i'm happy to let you know what i've done on my GTR.
just PM me
Sorry to hear Matt, I have been there and done that myself...except to a RB25 and ringlands.
If you need any help or info on rebuilding let me know and I'll help where I can.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
