Thanks again to Madaz for the NPC clutch he sourced a couple of weeks ago for me - its rad...
Picked the car up with the 33 S2 box and clutch fitted and did a hills run to wear it in. Have to get used to just how firm and precise it is but I finally have all my power going to the wheels.
Winning.
-D
  • Replies 3.6k
Posted Images
You'll love it ben. Try some hill starts in both forward gears and reverse. My pedal feel changed overnight about the 700 km mark.
Not a bad idea at all!
Also kudos to Shaun and Will at Boostworx for not only getting the job done on time, but they managed to come in under the price they quoted, in spite of having to do extra work. Great service!
-D
^gotta like that! Is that still a five speed box or was that the first of the six speeders Dohmar??
Nah its a 5 speed. Series 2 R33 GTR box (dual synchros tho). Still have many KM to make the gearbox lube up and unlimber. Every gear was stiff when I first started driving but now 3rd and 4th are feeling normal, 1st, 2nd and reverse are getting there, just need to shift in and out of 5th for a bit as theres a lot of pressure when I move the shifter to the right. I'm sure it'll go away in a while (box was stripped and cleaned in many fluids I dont even know the name of and reassembled with martini mineral oil used for the gearbox (not that blue shockproof shite!)
Box had to get converted from pull to push, thankfully BW has done it a lot and they have their procedure down pat...
-D
Inspiring conversation with Matty S this afternoon - you sir are indeed a champion !
Thanks ever so much mate. This world would be an amazing place if there were a few more decent beings like yourself around......
Hold your head high and be proud :cheers:
$860 del. from usa-ebay for Tomei type A or B, to suit Neo Rb25
$205 del. from usa-ebay for Cometic MLS head gasket to suit Neo engine.
A good place tog et stuff from is Raw Brokerage, if you arnt keen in ebay purchases.
www.http://rawbrokerage.com/main.sc
hope that helps a little.
yeah i was the fastest in it last (run) simulator event night
its as close to racing without being in a 100k+ race car
there is a weight limit of 90kg based on the seat actuators obviously he could put bigger in but then the build cost blows out
such a shame
thoughts are with Colin Edwards and Valentino Rossi too........they must be equally as gutted having been involved in such an unfortunate accident. 2 motorsport deaths in a week, such a shame :(
who do u have to get ya misses to blow to have a shot :rolleyes:
RIP Simoncelli, one of the most exciting riders to watch this year. live footage is pretty upsetting
He will be certainly missed. Was very sad when I heard that in the news this morning :(
well i tried to run another full blown event but wasn't enough interest so i canned it
Hey I am keen anytime :D
I'm trying to fix my harness in properly and having some troubles. Anyone know where I can get or have made a 10 x 1.25 pitch eye bolt? Very much like the link following
http://online.coventryfasteners.com.au/OA_HTML/ibeCCtpSctDspRte.jsp?section=3215688
-D
I use Redline in Everything, the Blue smurf blood, shockproof isnt supposed to be used in gearboxes, unless specified(some front wheel drive cars ) , it will damage your synchros since it reduces friction so much the synchros smash . you need to use MTL or 90 weight Redline oil I dont know how many people dont listen to proper advice and blame a product for the failure.
call redline in oz, great people to deal with.
I use 140wt Smurf Blood in the aftermarket LSD. and it lowers the temp a lot and hooks up in a instant, way better then the nissan oil, or synpower crap.
and MTL on my trans,metal part of the shifter never even gets hot now. !!! and synchros dont clash as before , had synpower for a few hours before dumping that out
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
