31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 308
Posted Images
LOL, well I'm off uni now till exams, I could come along hahah (not that I'd be much use.. lol)
I think the base one was a 1.6?? Maybe had engine replacement?? @290 I wouldn't be surprised?
How can you be so excited over a $800 car vs say a 15k R34 GT lol.
Perhaps he doesnt realise what a nice car he has ...
James it looks virtually identical to yours in almost every aspect ... wheels and everything hahah Maybe it IS your car :O?
Thats a good point.. I was just wondering why I was so enthusiastic over a 100hp car
Well im buying this one fully with my own money made from work, the R34 was paid for by parents ... I never like people paying for my stuff though, which is part of the reason of why I want a lil bunkie for my own
Ahh you're lucky, I still havent even had my exams yet .. finish on the 18th :(
Hopefully its a 1.8 and he just screwed something up ... regardless its still a nice looking car with a sweet interior rolleyes.gif
Yeah it'd be cool if you came along :)
PM us your number and I'll send you a text or call If I manage to get time to see the car
This ones on murray street .. not too far from subi!
Ahh I see, I don't even know when my exams start .. just realised theyll be starting soon, had a minor panic attack
Edited by Jonno34
Mine was a 1.8. Fairly sure the SSS N13 Vector was a damn rare car, especially in white. http://forum.pulsar....ormation-thread 27 only apparently?
the SVD is diffrent to the normal SSS. the SVD's are the more rarer cars ( ~200 made 27 white ones made for the F1).
for future refrence
models:
GL = base model, 1.6L singe point injection. drum brakes at the rear
GX = 1.6L standard, 1.8L EFI optional ( i believe). 4 wheel disc brakes
GXE = 1.8L EFI standard, chrome pieces. otherwise identical to GX
SSS = 1.8L EFI standard, 4 wheel disc brakes, diffrent extractors from factory, LSD
Ti= sedan only, basically the same as GXE but in sedan form
SVD = ( look at the link in the quoted post
Edited by liger
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
