  • Replies 132
Posted Images
Members only entries will end 1st of October..
There will also be no rollovers to the new year as its too hard to keep track of over such a long period of time,
Should you be unable to attend PM me and we will discuss it further.
Also Andrew I got your form :D
hey i'll help out again...but only if i can be gatekeeper again :P Owen... sun screen is a must. i got roasted on saturday :(and we needed more 1's and 2's for numbers, and scrutineering sheets :)
from the timing sheets it looked like we could've started from #30 & up, just need to make sure we're clear on the numbering system for next time :)
ohhhh yeah. i mean i went brown on sunday.... but i don't want the missus whinging at me ;Pwas good fun running around getting everything sorted.
nothing wrong with brown skin, just sounds like she needs to get down with the brown :nyaanyaa:
new entry form fax0r3d
jim berry clutch means the tyres will be the only things slipping.. just the way we like it :D
I hope you installed a scatter shield with that clutch... :P
Mark: One day mine will run again too!
Payment made and entry form emailed for Charles and Clinton.
After the fun that we had at the last one we want to have another go. :banana:
Welcome to your new addiction
is there an age restriction on passengers? My cousin and I were going to come along and bring his younger brothers who are about 13-15 for some hektik skids.
Where can I buy a super cheap turbo charged super skid machine?! A) I need super skid practice and B) my GTR wouldn't survive anywhere near the punishment I witnessed in September!
Buddy - you've got a R32 GTR. Pull fuse - rip mad skidz!
Seriously though, you can choose to run as hard or as quick as you like. The ride I gave you wasn't a fast run, was just a bit of side step clutch fun sliding around. Much faster to not slide so much.
It's all good and fun how ever you want to run.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
