So it flogs the pants off a CV8 Monaro, R33 GTST (albeit mostly stock) and a few other miscellaneous cars.
It's s bit slow getting onto boost but reels them in quick if they do get ahead. Gets to redline pretty fast in 1st and I've had the rear step out on me a fraction in the dry. :thumbsup:
Still impressed - but still trying to bleed this damn cooling system 100%
Sean
told you it's a bitch.
have a read of this
co.pdf
  • Replies 165
I found a good and quick way to bleed the system. Fill it as best you can and drive the car a short way, you will most definitely overheat but you need to get all the bubbles moving. Once the thermostat has opened fully you can crack the rear bleed and get all the air out. Now you need to make sure the overflow is full as when the car cools down it will fill the system automatically. Repeat the next day after filling from the rear bleed point when cold and you should be fine. Its the only way I have found without doing it a dozen times or more.
I just let it idle for half an hour with the cap off and just keep topping up as It disappears, has worked for all my cars.
it won't work man, its an m35
you have to invert them and bleed it from the sump
lmao i think they just wish they had bought a car with as much style as a c34, the m35 looks more like a childs toy or maybe a strange sex toy. although that would explain the childish things they say some times :P the manual transmissoin makes the c34 more enjoyable anyway.
good to see someone getting results from a turbo replacement, cant wait til i can drive mine again.
Your right Ive only done it on the following engines - 3tgte,18rg, 2tg, 5sfe, ls1, rb25,18rc, awu, didn't realize there was a big airlock in the m35 point sorry.
Should have found similar issues with the ls1 just quietly
Edited by Jetwreck
The M35 guys are sensitive because they picked the uptight upper-class girl.
We chose the cheap loose & easy slapper.
Uptight maybe, but get her in her element and she'll rock your socks harder and leave you with a bigger grin than some cheap & loose slapper.
Love the comparisons though :happy:
lol... obvious troll is obvious.
Isn't lilcrash the same guy that had a standard C34 faster than a Typhoon or something and was going to do a 400m to show us his standard C34 13 second run....I wonder what ever happened with that!!!!....or am I mistaken and it was someone else.
No that's me. I still don't understand what is so un believable about beating a typhoon. It's just a falcon. I supose you think v8 commodores are quick too.
And my comments were only jokes anyway, I'm actually growing fond of the m35 shape.
sorry mate.......took the comments the wrong way!
Nothing beats the 260rs for looks btw!
back in the day when I bought my stagea series1 C34's were 20k+, series2 autos were 27k+ and manuals over 30k.
the M35 model wasnt available.... this was 6yrs ago.
nowdays any stagea model is very affordable - simply depends what rocks your boat.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
