So it flogs the pants off a CV8 Monaro, R33 GTST (albeit mostly stock) and a few other miscellaneous cars.
It's s bit slow getting onto boost but reels them in quick if they do get ahead. Gets to redline pretty fast in 1st and I've had the rear step out on me a fraction in the dry. :thumbsup:
Still impressed - but still trying to bleed this damn cooling system 100%
Sean
told you it's a bitch.
have a read of this
co.pdf
  • Replies 165
I found a good and quick way to bleed the system. Fill it as best you can and drive the car a short way, you will most definitely overheat but you need to get all the bubbles moving. Once the thermostat has opened fully you can crack the rear bleed and get all the air out. Now you need to make sure the overflow is full as when the car cools down it will fill the system automatically. Repeat the next day after filling from the rear bleed point when cold and you should be fine. Its the only way I have found without doing it a dozen times or more.
I just let it idle for half an hour with the cap off and just keep topping up as It disappears, has worked for all my cars.
it won't work man, its an m35
you have to invert them and bleed it from the sump
lmao i think they just wish they had bought a car with as much style as a c34, the m35 looks more like a childs toy or maybe a strange sex toy. although that would explain the childish things they say some times :P the manual transmissoin makes the c34 more enjoyable anyway.
good to see someone getting results from a turbo replacement, cant wait til i can drive mine again.
Your right Ive only done it on the following engines - 3tgte,18rg, 2tg, 5sfe, ls1, rb25,18rc, awu, didn't realize there was a big airlock in the m35 point sorry.
Should have found similar issues with the ls1 just quietly
Edited by Jetwreck
The M35 guys are sensitive because they picked the uptight upper-class girl.
We chose the cheap loose & easy slapper.
Uptight maybe, but get her in her element and she'll rock your socks harder and leave you with a bigger grin than some cheap & loose slapper.
Love the comparisons though :happy:
lol... obvious troll is obvious.
Isn't lilcrash the same guy that had a standard C34 faster than a Typhoon or something and was going to do a 400m to show us his standard C34 13 second run....I wonder what ever happened with that!!!!....or am I mistaken and it was someone else.
No that's me. I still don't understand what is so un believable about beating a typhoon. It's just a falcon. I supose you think v8 commodores are quick too.
And my comments were only jokes anyway, I'm actually growing fond of the m35 shape.
sorry mate.......took the comments the wrong way!
Nothing beats the 260rs for looks btw!
back in the day when I bought my stagea series1 C34's were 20k+, series2 autos were 27k+ and manuals over 30k.
the M35 model wasnt available.... this was 6yrs ago.
nowdays any stagea model is very affordable - simply depends what rocks your boat.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
