havent updated for a very long time.
cars painted
cars on the road
car goes like a ripper
went to a dyno day today pulled 288rwhp on stock turbos on 15psi
some recent pics here
  • Replies 61
Its a faaaarkin awesome build dude not knocking it for a second but a 2J has 500cc more so personally i think it can do alot more than a 1J sure it could probably go toe to toe on a dyno in a HP shootout but that half litre more just gives you torque more turbo response which may not look that different on a dyno but the drive would be very different
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
awesome work mate love it. want to know how you made the engine mounts as im looking to do the same to my r33. i already have motor as i own a jzz30 soarer as well but want to swap motors any info would be great
i have found mounts for your s series nissan crossmembers and from memory the s14 crossmember are interchangeable with r33 not 100% sure though and as for the sumps im not to sure about that will have to look into it
you need a front sump yes. i have a few rear sumps here and they are useless i cant even sell them!!
i made my own engine mounts and run the r32 cross member and rubbers.
just sit your engine in the engine bay where you want it and fab up the mounts yourself.
get the motor as low as possible and as far back as possible.
pretty simple if you are handy with the tools
  • 4 weeks later...
so the engine was down on compression and the valve stem seals were causing a lot of smoke
so i got stuck in and built a new 1jz up for it. took me 2 weeks to build it myself and get it in and running.
got the urge for more power so i went with a t66 turbo, and a few little other supporting mods
still runnning a stock ecu with safc2 controller
finished with a total of 413 rwhp 308rwkw at 24psi
here are some pics
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
