havent updated for a very long time.
cars painted
cars on the road
car goes like a ripper
went to a dyno day today pulled 288rwhp on stock turbos on 15psi
some recent pics here
  • Replies 61
Its a faaaarkin awesome build dude not knocking it for a second but a 2J has 500cc more so personally i think it can do alot more than a 1J sure it could probably go toe to toe on a dyno in a HP shootout but that half litre more just gives you torque more turbo response which may not look that different on a dyno but the drive would be very different
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
awesome work mate love it. want to know how you made the engine mounts as im looking to do the same to my r33. i already have motor as i own a jzz30 soarer as well but want to swap motors any info would be great
i have found mounts for your s series nissan crossmembers and from memory the s14 crossmember are interchangeable with r33 not 100% sure though and as for the sumps im not to sure about that will have to look into it
you need a front sump yes. i have a few rear sumps here and they are useless i cant even sell them!!
i made my own engine mounts and run the r32 cross member and rubbers.
just sit your engine in the engine bay where you want it and fab up the mounts yourself.
get the motor as low as possible and as far back as possible.
pretty simple if you are handy with the tools
  • 4 weeks later...
so the engine was down on compression and the valve stem seals were causing a lot of smoke
so i got stuck in and built a new 1jz up for it. took me 2 weeks to build it myself and get it in and running.
got the urge for more power so i went with a t66 turbo, and a few little other supporting mods
still runnning a stock ecu with safc2 controller
finished with a total of 413 rwhp 308rwkw at 24psi
here are some pics
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
