www.durafix.com
Discuss!
p.s. I barely got half way through the vid and I skipped ahead to eBay and bought a pack of 20!
p.p.s. if anyone is concerned about strength, there's another video when a guy has welded 10mm plates of ally together at right angles, smacks one side with a hammer and the ally begins to bend before the weld fails!
p.p.p.s. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270768970566&ssPageName=STRK:MEWNX:IT#ht_3105wt_1139
https://www.sau.com.au/forums/topic/368666-durafix-easy-weld/
Looks handy to have around, but its around $50 for 40 rods and you need an oxy.
i'd love to try it for rim repairs though
See that eBay link? $11 US for approx 10 rods... Looks like one does a fair bit too...
You don't need an oxy set-up, just a butane torch...
Pretty fkn awsome if it holds up as well as it looks...
Ha ha... I wanna see someone 'solder' up a cooler pipe work set up-
I've bought some for the sole purpose to re-doing my intercooler piping and making an airbox, so I'll update in this thread how I go!
Edited by StealthX
this stuff has been around for yrs i saw a display at a car show over 20 yrs ago i was pretty impressed then . ive never used it but i can see it would be handy to have a few rods in the workshop.
  • 3 months later...
I used this stuff to make up an intake for my car. Turned out OK, considering I have no experience with welding etc.
I used a LPG gas bottle from my bar-b-q, with an appropiate nozzle, to heat up the material. One thing to remember, if you are making something with a few separate parts (like I did), when you heat it up again to stick the new bit on, there's a big chance the original "weld" will start to run. To help with this problem I bought a block of modelling clay and pushed some around the first bit/s to act like a heat sink.
anyone know if they have something similar for steel?
i've got a stick welder and we're trying to modify a pocket bike exhaust onto a motorised push bike (using the band expander)
the cheap chinese steel is so thin that its got a few holes in it
just want something solder like that will work like this does
They usually have a stand at farm machinery days and will weld up any alloy part you bring in to get done. They are very good at it and make it look very easy. I've tried it in different things and it works OK, but I found that using the normal commercially available alloy brazing flux and 10% mag rods is about the same. This was using a Dillon/Henrob oxy.
Chinese metal for things like your talking about is usually terrible stuff to play with. Its usually recycled tseel with inclusions all through it. And then you say it is an exhaust pipe or some such - double whammy. Nothing like exhaust pipe for dirt and crap in the metal.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
