  • Replies 91
I hear they are almost 2000rpm laggier than -5s?
Dyno sheet?
http://s1206.photobucket.com/albums/bb446/nismoboy_r34/?action=view&current=IMG_0835-1.jpg&t=1315813508740
it doesnt drop off boost at the end, the cooler piping pops off.. not sure what the -5s do but im sure its not 2000 rpm slower there pretty much on full boost at 5600
full boost around 5900, with cam gears, was the poncams dialled in as well, still laggy for the street imho
Going off the graph its 6000rpm.
That's worse than GTRS which are what, 150-200 more?
Can tell you now if its not 2000rpm, its not much less for -5s
  • 2 months later...
Hi , Signed up an account to replay to this thread :D
I have an R33 GTR with these turbos and have had them running for aorund 8000klm now .
a couple of things to know :-
mine had to be run in for about 1-1500klm because of the bearing type
Use a thinner oil for the engine , i use 10w30 redline - many use alot thicker oil and this will make a big difference to turbo lag with drag on the bearings.
Use the factory manifolds unless you have other mods which need otherwise. The manifold to turbo flange is smaller on the factory units increasing gas veocity into the exhaust side of the turbos making them spool at lower rpm . The expreme setup has a larger opening which breaths better at higher rpm but reduces exhaust gas velocity at lower rpm- this makes a big difference with spool up at low rpm.
Use poncam b's , they increase duration of the opening of the exhaust valve by 5 degrees NOT lift - they are easy to install and increase exhaust gas pressure making a noticable difference. you dont need adjustable gears for this - they are pegged for stock cam gears . Adjustable gears are not really required for mild tuning like this.
Mine start to spool at 3200 rpm , have fully spooled up to 1bar at 4000 rpm and keep this steady until redline.
Im upgrading my fuel system and plenum this winter along with arp head studs and a cosworth head gasket so hoping for 1.2 bar next year reliably :)
Once everything is finished ill get a dyno sheet and post it up !
7655 sounds a lot like garret gt2876
Going to jump on the computer in a min. Will confirm wheel sizes then
edit - 68mm comp exducer 6/6 blade wheel and 56mm turbine wheel with 12 blades
and according to tomei still journal bearing
So to me and my quick look around, they are a TD05-20G in custom housings
I've decided to pull mine off and change to a single turbo set up! They are advertised in the for sale section if anyone is interested,
I never turned them up, on 12psi they started making boost at 3200rpm & were agressive once on 12psi at 4000rpm.
and surprise surprise, the ARMS8260's look to be a TD06H turbine wheel with possibly a Garrett GT 76.2mm comp wheel (its isnt a 25G wheel as they are 78mm)
You clever bugger, you seem to be right about them using MHI parts. So all they have done for these turbos is add custom housings and mix/match MHI/Garrett parts.
A forum member on Club high rollers EZYWIN has the above turbo's his doing back to back testing from -5 this week according to his forum update. Pretty sure it made 530awhp on E85 -5 tuned by godzilla motorsports.. Lets hope for something a little more impressive than the smaller tomei turbo's. :domokun:
Have you had 50 or 60 in it? How much effect was it having?
I certainly wouldn't be going that thin (on hot) with a RB26. Least of all just to help crud turbo's spool.
Update from CHR:
First things first. Thankyou to GODZILLA MOTORSPORT, Mark and Darren for there on going passion to my car and the overtime they have spent on EZYWIN. Well those Tomie turbo's Kick Arse and make power. First Dyno Run 530hp @ 17psi at all 4's, that power equals the power i had with the garrett -5's set up with 24 psi. So we made just over 600 at 25 psi. Happy figure at 595 @ 24 psi. So there is a little down side LAG 5000 rpm then Hello. Went for my first drive today and oooo mummaaa powerplay and willowbank here i come. Tomie quality a big yes.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
