Hey guys,
Will be making a purchase for a front pipe and dump pipe in the next week. The exhaust system is for my RS four S stagea, interested in the Bellmouth front/dump pipe in the following link. http://justjap.com/store/product.php?productid=17316&cat=&page=2
My question is will i need the R34gtt version for my stagea considering it has the "neo" engine or will the one in the link be fine and be a direct bolt up. If anyone else has any recommendations and have used various different brands that were directly bolted up to your 25 neo feel free to share.
https://www.sau.com.au/forums/topic/369040-frontdump-pipe-question/
Hey guys,
i have got the sameone on my stagea perfect fit bolt strait up. Bolts are a hard fit on the back of the turbo because the bigger belmouth but still good.
http://www.skylinesaustralia.com/forums/topic/221282-stagea-s2-aftermarket-dump-pipes/page__hl__dump
http://www.skylinesaustralia.com/forums/topic/302514-series-2-dumpfront-pipe/page__hl__dump+pipe__st__20
http://www.skylinesaustralia.com/forums/topic/284923-just-jap-racing-3-stainless-dump/page__p__4795907__hl__dump+pipe__fromsearch__1#entry4795907
as i said - there are mixed reports as to how well they fit - but that could be purely a reflection on the build quality of them from a start - every one might be slightly different?! grain of salt. most importantly - let us know what you decide on in the end and how it fits. it's good when people who start a thread asking a question, post the answer when they find it. :thumbsup:
I got the bolt in but it was a mess around (you have to do it up first like a quater at a time, as you screw the others in), my JJR belmouth also rubbed the floor slightly so I gave that a slight "massage" other that that easy install. Now I done it a few times it's easy peasy.
I've got a jjr bellmouth dump. It fit perfectly except the bolt that can't be put in I snapped it off and never bothered to replace it so I didn't have that problem. Now I've got a hypergear turbo and I have to get it shortened because the turbo is longer and the exhaust doesn't fit anymore. Keep that in mind if you do a turbo swap in the future.
ive had a jjr r33 one and it fit, then i swapped for a r34gtt, split pipe and it also fit, but the jjr was very close to the gearbox holder and rubbed at low rpm for a quick second.
all in all, both fit, and yes, the jjr has that stupid bolt you cant get in. *shakes fist vigorously*
Thanks for all the input guys need to get rid of my crappy custom made system for something a little better and higher flowing only considering the bellmouth due to the price, and with the money i have saved i can buy a nice 3" high flow cat and a 6 pack to drink during the install :cheers:
I would recomend to not get the high Flow cat from justjap it is not as highflow as u may think as i found out and buy a catco cat or metal cat a little more expencive but well worth the money I got 3 quotes before I did the dump pipe back and they all told me to put the justjap cat in the bin they are more high flow than standard but not buy much and it holds the turbo back I got a catco now big difference
    • Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
