Guys
I'm on the hunt for some ID2000 injectors and am being told different things by different shops. Coming here to hopefully clear it up.
this is what i've been told...
Injector Dynamics don't manufacture injectors they flow test and report injectors and publish results that are inflated. This is due to using Petrol as testing fluid, rather than calibration fluid that the manufacturers use.
Bosch is the manufacturer of these units and this injectors great success comes all down to Bosch being the current market leaders with injector technologies.
We (powerflow performance) offer the same or some customers say, a better level of service and product quality to the ID products.
All fuel injectors sold by Powerflow Performance, undergo flow testing and packed into matched sets within a maximum of 2% variation. *Note* 1680, 2000 & 2200cc injectors matched tolerances of up to 5%.
so...is this true or false?
And who here has any experience with powerflow performance in melbourne? if yes, good or bad?
thanks
https://www.sau.com.au/forums/topic/371443-id-injectors/
Of course the sales rep is going to say their product is better
I use genuine ID2000's and the car idles and drives like factory.
I used a local injector (wont say name) previously and it was terrible.
Well worth spending the coin on the proper gear and not trying to save a few dollars when it comes to injectors.
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921456
Guys
thanks
Powerflow is VPW and they are a fantastic company but to rubbish ID's is just crazy, it shows a lack of understanding on their behalf.... maybe too many carby guys there.
Out of all the injectors ive used over the years the ID's really do perform as per expectations... im happy to pay extra for matched sets..... my egt results confirm it.
btw 5% of 2200 is a whopping 110cc......
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921502
By local injector, do you mean a locally supplied or locally made/highflowed injector?
If locally supplied, was that also a flow matched bosch?
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921524
Retail is only $750 with adaptors for the ID1000's and $1050 for the ID2000's. Any more than that and you're paying too much
I know theyre the same injector, but are you talking about ID2000's or standard bosch 2200cc EV14's straight out of the packet?
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5923943
injector dynamics modify the existing bosch ev14 injector with there own nozel. because they are a ball type injector this is posible. (not a pintle and seat.)
The bosch and ID injectors are identical. Injector dynamics take a bosch injector, put their pretty nozel on the end (which makes no difference to the spray pattern), machine off the last 3 digits of the part number and flow and dead time test each batch.
When you buy a bosch injector locally, you get the same bosch injector, last three digits of the part number are machined off (to protect bosch) and they are flow tested etc.
I know if I had the choice, I'd be going genuine Bosch, unmodified and exactly how they were intended. They flow the same anyway and the price is better. Win/win
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5925276
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
