Sorry for the blond questions I understand that a nistune is a mod done to the ecu but Im still getting the jist of this stuff as I am an old school carby and distributer nollage so I'm getting the drift of this ecu and afm and stuff Cheers
All good, best way to learn is to ask. So does it all make sense now? rb20det, r32 rb26det and r34 rb25det ecu's are the only skyline ECUs that can be nistuned.
Im thinking about going auto in my 33, just wondering if a modified Z32 ecu running nistune will run the auto the same as an r33 ecu would in regards to timing changes on shifts?
we have done it but its not controlling the auto correctly, the separate auto ecus are wired different
  • 2 months later...
Great thread.
I'm trying to gather information to help me decide on the best route to take with my car. A reputable shop in Brisbane is suggesting I go the powerfc over a nistune for my basic mods (pod, fmic, exhaust). Reliability and bang for buck are what I am most concerned with, just want something that is RELIABLE and will leverage the mods I have (would be happy with anything up to 200rwkw).
I was a little confused by what this shop suggested as from what I have read, Nistune sounds like the best option for me??
Both will do what you are asking with no issue, sounds like the shop prefers to tune the power FC and that is why they are recommending it. I would go nistune personally purely because it is cheaper and it looks stock/will pass a defect inspection.
Edited by Rolls
I would put money on they tune power fc's more than nistune and they know their way around it better.
At the end of the day it's your decision and you do what you like with your money. IMO they are both as good as each other and nistune would probally be the cheaper option. I went with the power fc because i found a cheap one and jumped on it, some people love them and some people hate them It's your choice do as you wish.
Ok, so would I be correct in saying they are both capable of achieving the power/results I want and both will provide the same level of reliability? Seems like the only thing splitting them is cost? I would also assume the PowerFC would be more capable when moving onto stage 2/3 tuning and into bigger power figures (which I am not planning on)
Maybe I just need tochat to some other local shops that aren't averse to nistuning. Would the average tuning shop handle both, or do they usually specialise in a particular make?
Both will be fine. Some tuning shops may never have seen a Nistune and may be hesitant. If you can't find a good tuner for the Nistune look for a cheap PFC but Nistune should work out cheaper.
What is 'stage 2/3 tuning'? Play less Need For Speed man :P
The ECU doesn't make the power, fuel+air+spark makes power. And that is all in the tune. A PowerFC is going to be no more capable or reliable than a NIStune unless the tuner is more capable with the PowerFC, etc. There's cars around making over 600kw with NIStuned ECU's.
Edited by Hanaldo
Lol @ stage 2 tuning
Seriously though a good tuner should be able to tune anything you give him, if they are iffy about nistune OR powerFC I would find another tuner for that reason. They are both incredibly common in the skyline scene so any tuner who does these sorts of cars regularly should have bucket loads of experience with both ECUs.
If you don't think a group of recommended mods done in a particular sequence can be classified as different stages, fair enough. I only know what I have read, so my bad if i'm using terminology that isn't cool.
I think i'll shop around for a good tuner
People just tend to laugh when you say stage 2 or stage 3, because what the hell is stage 3, is it adding a bigger turbo, is it changing your fuel latency value? is it a combination of exhaust housing and injector swap?
It is completely arbitrary so it just sounds a bit silly.
I would get a Nistune and only go for proper standalone ecu (haltechs, motec) if you need to upgrade
Correct me if im wrong but i understand the PFC doesn't retard timing if it detects a knock, just flashes engine check light on your dash
I know you should backout if you see the check light but I would like a little insurance from the ecu if it does happen...
That's my 2 cents
True on the Power FC. Also true on Nistune if you have made the knock maps the same as the main maps, which is necessary one a lot of cars when they suffer from phantom knock (ie the ECU thinks there's knock when there isn't and switches to the soft maps). I had to do this on my R32 RB20DET for that reason. It has run for years like that and I've never heard a tinkle from the engine bay.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
