hey guys i need some help i have recently found out some either really good or really bad new this week still not too sure yet but basically we pulled the head off and looked down the bores and 2 of the cylinders have marks that you cal feel with your finger nails...looked and the head and the same valves for those cyclinders had a white colouration to them im guessing it ment they were leaning out?
anyway im looking at a full rebuild plus machining and all that for the bottom end i was wondering on your opinions i was thinking forged bottom end but i am new to this so if i can get some help it would be fantastic....i was thinking westend performance in campbelltown for the machining and im from wollongong there is a couple of good engine shops down here but if i can get some ideas on shops or combos that would help alot thanks guys will post photos and stuff of the stock gear and the build along the way
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/
really depends on your budget and the direction you want to take your car, like i said before, the cheapest and easiest way is probley to just buy a complete engine and drop it in, you can get them for around $3500 and $4000 or....
there is a 2.7 jun stroker kit for sale in the for sale section just needs a set of pistons which would work good for you since you are going to have to boreout your block to get rid of scoing so you can just buy what ever size pistons you need after you find out how far you have to bore it or....
i remember seeing a built 3ltr i there some where aswell ready for a 26 head.:thumbsup:
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5928080
Thanks you for the post.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5931208
Definately get Aarons one. Like i said on the phone it would be an awesome buy and with turbo's etc will work out the same cost as a rebuild without the headaches
I can tell you about that engine. I bought and installed that into the car. I can assure you it's 100% genuine R34 N1 Nur engine. I purcahsed it brand new from nissan in japan. had it fitted to the R32. and then imported it. I sold the car to aaron a couple of years ago and he's been a very fastidious owner ever since. I don't know what he's asking for it but I know what it cost. if it's anything around $5K it's a steal. it's very low km and will handle plenty of power.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5931361
ok sweet how long did you own this motor and how many kms did it travel with you?yea i have read they can handle like 600hp but if i can get anywhere over 300kw atw ill be happy and obviously wind it down for normal daily driving to around 220kw i think that should help the motor last a lil longer but yea giving the mechanic a call today about it and hopefully pick it up next weekend providing its all good....
i did however find this for a bottom end rebuild would you guys care to comment please?
http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb26dett-rebuild-kit
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5935046
I would have to check when exactly I purchased the motor (possibly 2009?). I bought it brand new from nissan kokura (japan) and it was checked and installed by Prime Garage (built cars like Yoshioka's D1 car, Super GT cars etc). I had the car for not long, maybe 1 year and I would say travelled less than 2,000kms on it. It was treated very well when I had it and I'm sure treated just as well when Aaron had it. He was a fastidious buyer (had the car and engine thoroughly checked before he bought it off me) and a very careful owner. Aaron probably has some pics etc from when I had it installed. i'm pretty sure I passed them on to him.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5935111
just checked, it was about June 2009 it was built. I also bought brand new R34 n1 turbos for it too. it also has tomei 1.2mm head gasket, and the head was expertly ported by Tetsuya at prime garage. From memory it had the inlet manifold etc port matched too. also fitted brand new injectors, brand new R34 crank angle sensor, 6 brand new genuine coil-packs, and ignition transistor unit (over $1200 just for those 2 bits). also had brand new N1 crank damper fitted, all new hoses etc too. Also has tomei timing belt and other gaskets. Just checked my bills, total was about $20K for the engine work, the engine, and fitting.
The car itself was immaculate too. I still have the old engine I removed from it to make way for the nur engine. That engine was still in perfect health too. If aaron doesn't have the receipts for it I still have copies I can give him.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5935127
sweet as i gave the mechanic a call today and he said he wont be able to get a look at it til mid next week so i gotta wait til then and hopefully he gives it the all clear cause im getting excited thinking about that baby in my car...yea those receipts would be amazing man thanks and do you know anything else about the specs of the motor or what power they were saying it would be able to handle cause ppl tell you different answers?
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5936057
http://www.spoolimpo...ett-rebuild-kit
Good price for a rebuild it with the dearest parts in it. Will handle more power then you intend to throw at it.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5936746
Kyle , I have all the photos and receipts from when i bought the car from beer baron all up this engine has done 42, 000 kms from when it was installed as brand new engine , if you did buy it all this information will go with the engine . Aaron.
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5936932
I think you should get it Jez and then get nur 32r plates :)
https://www.sau.com.au/forums/topic/371794-rb-26-rebuild/#findComment-5936989
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
