  • Replies 58
2 out of 2 cars ive run one in had cooling problems. Tested back to back to stock nissan rads which had no problems.
They are a cheap replacement if wreckers want a mint, and they do what they are meant to do.. But they do not do as good a job as stock and definitely not of a quality performance item.
If I have left you confused, they are good enough for a camry that doesnt get driven hard. Not good enough for a performance car that gets its ass kicked.
We had several issues with the neck sealing in the top tank. We ended up removing them from the car and had the neck welded up to stop it leaking.
As said above, they are a cheap get you out trouble type radiator.
Why are you replacing your current one?
For a track drift car, currently after going hard for maybe 15 min temps starting to go mid 90s to 100 so i wanted something that can cool more so im looking for somwthing suitable for track and by what you guys say this is a cheap replacment for a daily streeter. So i should look at the blitz?
for me, I've never had any problem with koyo. and to my mind less is more. so many people fit giant bloody radiators that do nothing more than add massive weight up front (no matter how light the rad is remember it gets filled with fluid). koyo make a nice upgrade that has standard type top tanks, is dual pass and not much thicker than stock. great piece of gear. look how thin a standard radiator is and how well they cool. ask youself if you need one 3 or 4 times thicker than that?
I'm happy with the $300 Cooling Pro I got from JJ. The neck is machined, so is tougher than the pressed metal of the alloy rad that was in there when i bought the car. Needed to trim a side off the shroud to make it fit. Havent tried it at the track yet though.
I didn't buy my radiator from justjap, I got it from authenticgodzillaperformance but I believe they are similar if not exactly the same.
I couldn't be happier with mine. Have had it at a few track days, never gets above 95 degrees even when the car doesn't see under 5000rpm for a good 15 minutes. On the street it sits solid at about 78 degrees, goes up to about 80 degrees when standing still. Doesn't leak at all except for the overflow line, but that's because my overflow line is a bit old and the fitting kinked the inside of the hose which breaks the seal. Will get round to replacing that, for now I just use a piece of larger hose squeezed over the top to give it more surface area.
So not sure if it's because AGP are actually different to JJR, but all their products are around the same prices.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
