hey,
so as the topic states i have rounded the filler plug on my gearbox whilst trying to get the lil bastard out.
just wondering if anyone has any ideas as to what i do now?
i read on an old DIY that you can refill the oil through a hole or something near the gear shifter inside the car?
iv had a look and cant see any obvious way of doing this, if anyone has done this successfully where am i ment to be pouring the oil?
thanks for any help...
https://www.sau.com.au/forums/topic/372334-r33-gearbox-oil-change/
hey i just changed my gearbox oil yesterday. tried to take out the gearstick but couldn't. then had to refill at the bottom. does anyone have a step by step tutorial on how to remove gearstick? i heard you need a right angled long plier to remove the stick?
ahh, so you take the shifter right out do you?,
mingy
theres a step by step how to in the DIY forums under installing a short shifter or something like that
ill give it a crack, hopefully my drain plug doesn't round aswell..
on that note my 1/2" drive breaker bar doesn't seem to fit snug in these plugs, any ideas on how to prevent it from rounding them?
Remove the two circlips and it will come off. 1/2 inch works for me, they shouldnt be that tight that it rounds it, just be careful when doing it and if you feel it slip stop.
alright got the shifter out no worries, then got back under to remove the dump plug and..... no bingo! rant.gif
i'm using a 40cm breaker bar WITH half of my garage jack handel on the end giving me a total of around 1.2m worth of breaking power, iv sprayed the crap out of it with Lanox inox
and still just feels like its bending the plug about to round it!!!
any ideas what to do?
the only issue with taking it to a mehchanic is once they get it out they will have to refill it so i cant get it home.
dont wanna know what they will charge me for a few hours labour and use of their shop.. :S
waiting on a new plug now so i can try the chisel... if that still doesnt work for some reason then ill have to take it to a mechanic haha
I had the same problem with my motorbike's sump plug, I tried everything but managed to get it using vice grips + hammer.. had part was getting those vice grips on super tight.
In trying everything, if the vice grips didn't work I was willing to sacrifice a ring spanner by welding it to the sump plug
Did mine yesterday and was tight but with a standard braker it got undone, was not worried about rounding it at all, there was alot of some form of sealant on the plug for sure, as it's only a shallow 1/2 inch plug just make sure the bar is in good and proper and let the guns do the rest of the work
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
