haha loved the vids Rich! I also noticed the problem you had getting into 3rd that you told me about! That must really grind your gears :P
Are you going to be at work tomorrow? Tried fitting the catch can but it seems i need to mod the bracket but ill see what you have to say first before i go cutting anything lol
cheers Oz
yeah I'll be around, give me a first to make sure 0411861466..
It should deffinately fit straight in, it did with mine, bring it round
I just remembered we did trim a bracket, bring it round I'll show you :thumbsup:
Edited by tricstar
  • Replies 121
Bubba went along with Camera, so maybe he got some :thumbsup:
Unfortunately my lack of wheels prevented me from getting up there :( My mate came off the track on Friday and didn't go back so I ended up playing with the r/c car instead :/
Right back at you Oz, good to meet you and some of the other guys. Good atmosphere there - relaxed and just plain good fun. Also whored myself out jumping into other cars - saves fuel! :) Great fun being a passenger.
Gavs car was as usual unreal.. we had 4 guys in the car, all 90kg+ and were still toasting people. How good is that..
Kev's Torana (Mumbo) was also just flat out fun with a shot of NOS. Awesome sound, smooooth power and deceptively quick. Threw the arm out the window to give some 'Torana Arm' and then he flicks open the glovebox and gives me a mullet-wig to put on.. haha! it was great. Noted also a timeslip in there with a 10.9 on it.. mumbo indeed..!
I'm booking my next years entry tomorrow. Great weekend.
Good to meet you :cheers: (even thought you are a cheat haha)
Was a mint weekend even with my traction issues, had to catch up to literally everyone after 2nd gear... The GTR's were killing me in 2nd gear running away scared haha, might have to run ET Streets next year.
Had a good run with Gav, he let me off to a flier to overcome the wheelspin... Was fairly close in 3rd but he managed to pull a wee bit when he went 4th :pirate:
Edited by SimonR32
sounds like you had the same problem as every other falcon and commodore there, smoked them all, 1000hp seems pointless if you can't get traction no.gif
I smoked them all as well without traction... You mad? :-) haha
Edited by SimonR32
heres a couple of average vids from my gopro- Hanaldo your in there but its not great, ( the video that is )
that little mazda in the last 2 runs is bloody quick, I had him in the second but on the shift to 3rd had a disagreement with the gearbox and he came flying past
and bit of cruising vv
that mullet was you Matt :3some:
thanks for that correction Kev, see you at the next event in your 34 :laugh:
Jimmy I would;ve run ya :rolleyes:
i had a look at ur beast with the bonnet up, looks mint :)
how come there was hardly anyone doing the events on sunday? was all the prize money given out on saturday or something.
cant wait for next year but, or even to get into some track days throughout the year
Yep all the awards were done on Saturday so there was nothing to go for on Sunday. I decided I had done enough damage to my tyres so called it quits Saturday night.
Simon, I'm assuming that was you in the green 32?? I did think it was you but then thought you had sold the 32? Not sure why lol.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
