  • Replies 64
You need to check injector PULSE and coil spark first. If you don't have either one, then yes, CAS is most likely
Coil spark by sticking a screw driver or something similar into the coil pack and seeing if it'll spark to the block? Or any other way you recommend?
Injector pulse by pulling one out? Of is it easier to intercept the injector signal and hit it with a multimeter?
ok. pull no1 coilpack out of the cradle, put the spark plug in the bottom of it and make sure its loom is plugged in. earth the threaded section of the spark plug somehow (i rest it against a screwdriver thats sitting firmly against a clean part of the head). pull the cas out, just undo the 3 bolts and carefully remove it, leave it plugged in. turn the ignition on and slowly turn the cas counterclockwise (looking at it from the shaft side), check for spark and listen for the injectors ticking. if you get either your cas is working fine, assuming of course the drive teeth are fine.
Use a jumper lead for the spark plug, much easier. Clamp one end to the motor, and clamp the sparkplug in the other end with the sparkplug plugged into the coil and loom like you normally would.
I can't help but think it's the CAS.
Do I just take it off the base plate (ie, undo the couple of small screws) or do I need to take the base plate off as well?
Yep ubolt the three screws, unclip the wiring and then just pull it out. Mark where the bolts were roughly aligned first to be able to put it back in the same spot.
Once it is out just spin the shaft and see how it feels. Like I said. There should be no resistance what so ever. When they snap the shaft it feels like grinding against sand.
Everything really makes it sound like the CAS so I would suggest doing this first prior to anything else since it is the easiest thing to do.
used to have a vl turbo and when the airflow was on the way out, it puffed alot of fuel and black smoke out the back, very similar to what your talking about, then eventually wouldnt start at all,
have you ruled the airflow out??
I picked up another one, which I can't be certain is working, but it made no difference. Aldo, the voltages seesm close (althought I need to confirm the V when cranking - my memory may not be accurate).
Fairly sure a Skyline will start start even without an AFM signal, just goes into limp mode, so I don't think it would be that.
With stock ECU, yes but don't know about PFC.
Shit I forgot about one small thing. You may have a split or dislodged intercooler pipe.
Check for leaks. AFM swap outs will not diagnose this and it will foul the crap outta your plugs. It will also cause it to run crap and basically every other symptom you described
Should still be able to start the car with throttle open though.
Everything really is pointing to a broken CAS spindle. As the starter motor spins the engine manually during start the ECU receives no signal from the CAS so won't fire any injectors or spark plugs to initiate combustion since it doesn't know the engine is turning over.
actually i can confirm that it would start, mine does without the airflow, just wont rev up pinch.gif ( with standard computer)
Yes, until the spark plugs are fouled....which takes about 5.3 seconds....and, unplugging an AFM is different to having one plugged in with no values being read
Yeah IF he has no spark and no injector pulse, but having a blown cooler pipe or a split one or even a semi large vacuum leak near the plenum will stop if from running. Details are vague over the internet so we don't want to rule out basics until they have been thoroughly checked
I've had a good hunt around for a split in any of the intake. Haven't found anything, but it was probably an 80% look, if that makes sense. It was running at the time, which would no doubt have helped substantially.
I will try and get an injector out, double check the spark and if nothing, pull the CAS off tonight.
I'm trying to be as thorough as possible so people can refer back to this as it seems to be a common problem caused by a number of things. If I can say "these were the EXACT symptoms, this is what I checked, this is what I found, this is how I fixed it," I'm hoping it will help others.
Go to repco or similar and buy a noid light.
This little guy plugs into the injector plug(easily without removing the plenum an fuel rail) and when u crank the noid light should flash. If it doesnt then there is no injector pulse.
Do some basics, check all fuses etc, then if possible borrow a mates CAS to try.
Now the fun starts.
JDMSpares wants a piece of my arse, but has made it abundantly clear they do not wish to use lube. $180+del for a CAS - tell him he's dreaming.
Anyone got a Neo CAS they want to sell to me? The going price looks to be more around $60-$90
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
