Here is some interesting reading. http://www.innovatemotorsports.com/support/manual/LC-1_Manual.pdf
Previously discussed, it does mention that the sensor should be kept to 900f. It is the same sensor that bosch manufacture and recommend a max temp of 1000c. Go figure.
It also recommends calibrating the sensor frequently so this mornin I'm gonna calibrate me a sensor, yup.
4.3 Calibration Schedule
Normally aspirated daily driver:
- Calibrate before installation of new sensor
- Calibrate new sensor again after 3 month of use
- Thereafter calibrate once a year or every 20,000 miles, whichever comes first
Turbo car, daily driver (tuned rich):
- Thereafter calibrate twice a year or every 10,000 miles, whichever comes first
Race car
- Calibrate before first installation of new sensor
- Calibrate once per race weekend
Dyno use
- Calibrate a new sensor
- Calibrate every 2-3 days, depending on usage
  • Replies 217
as i explained before the temps are at different places.
I disagree. I don't think that the difference you are talking about is measured by bosch. Could be but I doubt it. The sensor is the part that will die not the housing. It does mention on the pdf that for track use the sensor should be 36 inches from the turbo so it doesn't cark it.
SimonR32 youtube us up :thumbsup:
  • 3 weeks later...
Quick question for those using the UEGO, is the gauge supposed to not give a reading on decel? I installed my kit the other day, but haven't had much chance to play around with it yet. On the one drive I took it on, I noticed the gauge would display "- - -" while on decel, is that supposed to happen? I thought it may have been because there won't be much air going into the engine on decel, but then I thought surely if it gives a reading at idle then it should give a reading while it's in gear?
Edited by Hanaldo
This is why they say it's more fuel efficient to pull up to lights while downshifting rather than just putting the car in neutral. Fuel is required to keep the car running at idle. Your drivetrain is doing this under decel so no fuel is needed
Edited by 89CAL
Yep normal, gauge reads up to 18:1 and on decel the mix geats leaner than this so it displays those --- instead.
The XD-16 is discontinued, shame they didnt test the LC1 but I would assume it would be just as accurate from the comparisons I have done.
Lol @ PLX and NGK, + or - 1.0 afr... >_<
Still able to find them but they cost almost double the price of the AEM. I want to get one of these for my car, get rid of the narrowband and put this in its place. My ECU isn't using it so it would be just for me to monitor the ratios.
pretty sure the XD16 was used with the LC1 in that test. the XD16 is just the display, you still needed the LC1 controller to work with it (i had one).
I love my LC1.
Works great, and piece of cake to re calibrate. I quite like the re-calibration feature. Do it every time the car gets an inspection.
The only issue being they have a high failure rate. From what i can gather from the interweebs they changed their manufacturer at some point and there were a few dodgy batches around. I got one that failed withing a week.
But they replaced everything at their cost incl shipping. So thats good, and its been perfect ever since.
^ Plus you could also wire it into your ECU if it allows it and set up closed loop, and target AFR :D
So you are saying you can use the wideband and ecu to dynamically control afrs? Surely something my power fc can't do lol. I might pick up a innovative unit. Shop near my place has them plus 12 months warranty
Here are results from a wideband shootout, you can google and read how they compared it along with a industry sniffer.
Innovative is both accurate and quick to display it's numbers.
I remember this test. Very controversial test.
We have spoken to Mr. Mike Kojima the author of the Fordmuscle shootout and got first hand test details. According to Mr. Kojima his article was edited prior to the publication.
The tests were done using Innovate methodology and Innovate equipment.
There were several major flaws in the test, including but not limited to the way the O2 sensor was exposed to the test gases.
One of the major test flaws was reading the AFR value from the Zeitronix Zt-2 analog output using the Innovate logger. There is a voltage drop on the power-ground wire caring 12W of O2 sensor heater power and offsetting the AFR value. Reading the AFR value from the Innovate digital output but logging a raw Zt-2 voltage using Innovate logger subjected the Zt-2 AFR reading to the voltage drop, noise and Innovate logger analog to digital conversion offsets and conversion time.
The Zeitronix ZDL datalogging software should have been used to read the digital AFR value from the digital output of the Zt-2; not any other product brand.
Using the Innovate analog logger to read the Zt-2 (and other wideband meters) analong AFR value gave Innovate LC-1 unit, a half track length advantage in this 1/4 mile race. We either start from the same line or this test is not valid at all. This is an absolute violation and unscrupulous action.
The same goes for the "latency" measurement. The Zt-2 AFR readings were obtained by using the Innovate logger and software.
The Zeitronix ZDL software was not used in the test but scored the lowest.
For those who use our ZDL software know that hitting Enter starts logging, Enter stops. What's easier? "Clap on, clap off"?
Let me point out again that the other unit, which does not come with any logging software scored higher in the "Software" category.
Moreover, the Zt-2 scored the lowest in "ease of use" category. In order to get the AFR value from the Zt-2 all it takes is two wires to be connected to +12V and ground plus the O2 sensor placed in the exhaust stream. The Zeitronix LCD display plugs and powers up directly from the Zt-2.
As you suspect, Fordmuscle is sponsored by Innovate.
Eng
Zeitronix Inc.
A lot of aftermarket computers will take a wideband input in the 0-5v range, I've got my AEM output wire in place ready for when I upgrade my management and can make use of the wideband readings.
Having a local supplier for the Innovate would be good too given some of the failure info around just in case that still applies.
As an aside, My AEM shipped with an ever so slightly suspect 4 pin harness, I contacted my supplier through ebay and he had AEM send me another express from the states no questions asked.
Who you deal with from a retail point of view is just as important as which product you buy.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
