So, I'm not one for having gauges up the a pillar or on top of the dash so I'm thinking the attached fits the bill nicely. Oil temp and pressure and water temp. Black faces and white light, red needles, so pretty much like stock. Any thought on these or suggestion on alternatives. I've done a brief search but can't find much of use. If anyone can point me in the direction of a relevant thread please do so.
http://www.egauges.com/defi_info.asp?DP=din_top.html
Other questions are best place to buy and what is involved with installation. Do they plug in and use the factory senders and wiring?
Cheers.
https://www.sau.com.au/forums/topic/373691-gauges/
G'day Nick, let's not worry about gauges let's talk about your GT3 ok .... :P
But seriously, I don't know if I'd suggest these gauges. Where they will be mounted is a long way from your line of sight.... therefore realistically you'll seldom look at them.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5961126
GT3 has no silencing but for some large empty cans straight off the headers. It sounds like a figgin race car. Hope I don't get caught.......
I take you're point on the location of these, but when ever do you really look at the gauges other than 'when you can' in which case nowhere is a good place, and possibly no good time either! Specially if you've got 3 of them to clock...
I guess in tarmac you're always 'on', where as track work you've got the straights to check your stats.
I just want some way of knowing my real temps & pressure as as the OEM's are meaningless.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5961145
I just like to see them out of the corner of my eye, rather than having to actually turn my head and look at them, or worse, sort of kink your neck to look if they're in factory 32/33 GTR position.
I could forsee these being ok with the addition of a couple of warning lights for low oil pressure (@ 15/20 psi) and high water temp.
For my car I position them so I get used to seeing where the needles sit, like I say, just in the corner of my eye. But yes, I agree, a little ugly, but it works.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5961156
i've used these before. they are pretty good. only problem is no warning levels can be set. they come with their own sensors ( they do not interface with standard sensors/wiring etc). they are nice looking and easy to read though but yeah I prefer gauges where I can set warning levels then they let you know something's up with buzzer and a light.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5961560
For the oil system you're best to replace the sensors. Gauges that use a external warning light are the go. Best of both worlds, you can keen an eye on them on the straight, but you get a big red light if stuff goes wrong in the corners (which it will 99% of the time)
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962043
So for the sake of arguement, what about these? Questions would be:
Are sensors vehicle specific or is there an industry standard everyone works to? They off an STI
What type of workshop installs these? Autoelec or mechanic?
May have the engine out shortly (no 300ZX). Is this a good time to be fitting these sucker?
Do these having warnings?
Will people laugh at me for having blue gauges?
http://www.skylinesaustralia.com/forums/topic/367741-defi-bf-x-4/page__p__5867864__hl__defi__fromsearch__1#entry5867864
Please can you recommend some specific alternatives and where to get them from?
Thanks guys.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962435
I thought we were talking about the GT3?
You gonna bring that around and show me? :D
Nah, still got one of the 32s. GT3 is not for fiddling with, nor does it overheat etc so gauges are not necessary. Zer Germans built it you see. Would have been easier to give you a joy ride when you were south of the river. Drop me a line next time you're down my way.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962496
What ECU are you going to run in the 32 Nick? If it has a CAN interface on it then I would consider a dash that you can set warning levels on. Do it once do it properly!
I am not one for guages on the dash, but the PowerFC doesn't do CAN. So for my 32 I have some of those BF Defi's which show a light and buzz.
Using a just jap pod mount http://www.justjap.com/store/product.php?productid=17332&cat=&page=3
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962681
So for the sake of arguement, what about these? they are fine, defi make excellent gauges, adjustable warning points, record function (great for oil pres, you go do a lap with it recording, come back to the pits and then replay to see if you're getting any surge).
Are sensors vehicle specific or is there an industry standard everyone works to? sensors are not vehicle specific, they are universal. that goes for all gauge brands they all use generic sensors.
What type of workshop installs these? regular mechanic is fine or you can DIY, defi's are VERY simple to install. there's only 1 small piece of wiring (power and illum to the controller) the rest is all just plugging stuff in.
May have the engine out shortly (no 300ZX). Is this a good time to be fitting these sucker? they can be easily fitted with engine in place.
Do these having warnings? yes they do. high point warnings for temps etc, low point for oil pres and fuel pres.
Will people laugh at me for having blue gauges? possibly. psersonally I like white illum or amber, bit more subtle. even green is ok.
Please can you recommend some specific alternatives and where to get them from? personally I'd buy defi's but get the new models. the BF and defi-link (like the ones you linked) are out of production now so you won't easily be able to buy more if you decide later you want EGT or fuel pres (both very handy). so either try and get a complete set used, or buy the new models.
your other option is a dash unit like a stack dash or aim dash. cost around $2K for a basic one but does pretty much all you need.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962709
Using a just jap pod mount http://www.justjap.c...332&cat=&page=3
I've got a Power FC so it looks like the DEFI's may be the go. Where does the pod sit? LHS of the main instrument binnacle?
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962713
Or one of Paul Ruzzic's engine moniters that I use.
I have the series one verson of it and it gives readouts on oil pressure, oil temp, water temp, intake temp and boost as well as shift lights and high low warning light and siren for all the above.
The new one he is working on atm will do the whole 9 yards and then some includint gps for time splits, sector times etc with full logging capability and will cost way less than the imported stack dash and others.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962723
Yep spot on. I am however at the point where I don't mind screwing things into my dashboard! I guess you could stick it on with strong double sided tape, or just get a cheap second dashboard that you don't mind cutting into for motorsport if yours is in good nic.
End of the day if you are heading in the direction of putting in a roll cage you may as well cut to the chase! Its a good feeling having cars devoted to motorsport - maybe just go rip out your interior to set the wheels in motion, will make these decisions easier :thumbsup:
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962733
Actually yeah - thats a good option. Hmmm.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962735
yeah the ruzic thing is very good. the only one thing I'd point out is that it's still using factory sensors which by this point are certainly past their best. all the other options like stack, defi etc come with new sensors. it does mean the ruzic option is easier to install though.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962738
I replaced all the sensors in Mine Rich. I wouldnt trust the old oem stuff.
https://www.sau.com.au/forums/topic/373691-gauges/#findComment-5962745
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
