just looked all over it and there is no numbers unfortunately :ermm:
so why dont these housings flow if they are supposedly bigger than the .63 but smaller than the .82 in theory wouldnt that be a good happy medium between power and response?????
Im lost :wacko:
Mick I went over this before you bought the turbo. ARR is a ratio. There is no meaningful way to compare a non-Garrett GT30 based turbine housing with a genuine Garrett housing.
It will probably top out earlier than a 0.63 if it is an AVO casting.
Hang on a minute I just found the post.
http://www.skylinesaustralia.com/forums/topic/375232-garrett-gtx3071r/page__view__findpost__p__5985575
Edited by wolverine
If you just ask the supplier to swap your housing for the garrett one and pay the additional you will be fine.
Honestly, we are pretty much telling you there is no point even trying that housing and seeing how it will go. You will just void its value.
The supplier wont take it back once its used and you will not be able to sell it.
I assume you got your turbo from MTQ, just call them and explain you have changed your mind about the rear housing and would like to exchange it as it is still new and unused. Im sure he will let you send the housing back undamaged and exchange it for the garrett .82 provided you pay the cost.
If your housing is worth $400 new, and the garrett $600, pay the additional $200 then pay to send it to him and send it back to you and your laughing. No more mucking about, just do it.
but will it still make good low down grunt with the .82 cos i dont wanna have to rev its tits off it to find some fun power?
Will the E85 help with boost response?
Mtq are in wetherill park which is nice and close but i bought this turbo through boostn imports so i wonder if i will still have to go through him again or whether mtq would let me deal direct??? plus id need it before next weekend hope its do-able!
Would this give me my happy medium in terms of response but eliminating the boost pressure issues i might have with this bad flowing Avo housing that i have plus make more power than it??
Appreciate some opinions :thumbsup:
you need to measure your turbine wheel to see if it has a 60mm turbine or a smaller cropped turbine. if its 60mm then go to mtq and buy a .82 garrett housing to suit a gt30 and sell/return your current housing.
with a .82 IW housing i'd expect to see 1bar of boost around 3800-4000rpm on a mild rb25
Yeah that sounds alright id be happy with that thats not too shabby at all from the .82! its stock other than all the usual bolt ons and it will be on E85 too
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
