Haha cheers scott only couple of days now till i get to hear this lil baby scream :)mestamp='1316611486' post='6026347']
Ohh la la, look at that.
Now I am confident you will be a happy chappy :)
Lets see you crank some boost through it hey hey hey hey ;)
Just looked under my car and this dump pipe looks like its to suit a high mount manifold the offset from the turbo flange down to the flange that bolts up to your cat looks wrong im bolting it onto the standard headers :domokun:
Can anybody confirm this PLEEEEASE?
Gunna call liverpool exhaust and see what they say tomorrow because they made it
looks like its to suit a standard manifold to me. impossible to tell for sure from pics, but definately not to suit highmount.
The bit that heads up to the turbo does look longer than normal.... I think it might be to suit a high mount.
Not yet! Bottom end is in for machining / balancing at the moment, I should have it back next week. I still need to send the head off for a service. Then it's assembly time!
You get your car running with the gtx mate?
DVS JEZ and Mick_o have been hard at it all day, it is all installed and they are heading out to do the road tune soon.
Hopefully Mick can give us a bit of an update later tonite or tomorrow.
Full credit to Jez for patiently working through the issues that modifying cars can throw at you.
Thanks Andrew, glad u were there to give me a few neat little tricks especially the one on how U remove the side feed injectors from the rail. Loved that one.
Did a tiny bit of road tuning. Was wet and scary, but so far so good. Turbo is nice and responsive and has an awesome sound.
I just got home and left at 6 this morning. So a 16hr day. I couldnt leave micko there without getting it finished, i could tell he had been itching to drive it since he started ordering all the parts.
A big thanks to Jez for his effort today absolutely massive mate im cheering u are a champion :) sorry bout the onions i guess the saying once u go black u cant go back doesnt apply to onions hey? Lol i also want to thank Andy for dropping in and saying hi, checking up on us and giving us some helpful tips and especially for delivering my new cat Haha much appreciated mate.
We peaked 13.5psi tonight very briefly before the wheel spin in the wet.
My car did feel a bit livelier down low than your current setup but obviously hard to say without traction and proper tuning .
Was shocked how much my exhaust note changed from stock turbo and bodgey gutted cat to what i have now sounds awesome!
Cant wait for full tune and E85!
Think its gunna be a tough lil street package :)
Thats a bugger mate but i can tell you that you will be happy with your turbo selection from my first feel of my car today and the sound is good too :)
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
