Pulled my pcv valve out today cleaned it up it works fine but the rubber grommet on the other hand was stuffed when i pulled it out it broke in half :domokun: Nissan want $50 for a new 1!
Getting a new rubber tomorrow but used a rubber hose that i had and dodged it up and it didnt seem to play up as much so fingers crossed its sweet when i put the new rubber in :w00t:
Im getting frustrated cant get my tune done till next thursday now :rant:
A tune from Yavuz will be worth the wait
Ok so i just got home was a big nite thanks to the unigroup boys for staying back to finish my car it is UNREAL :worship:
Thanks for ya patience guys FINALLY the piece of paper you have all been waiting for!!!!!!!!:cheers:
Feels nice dude im stoked! To be honest i only gave it a lil squirt cos the boys in blue were about i think cos its drag nite at the creek.
You will find out soon enough mate when i bring it up your way :thumbsup:
Thats awesome bud. Hows it feel?
Nice work - glad that went smoothly, nice stout amount of power... definitely not a normal GT3071R :D
Tbh without any prompting I'd have thought it was a GT3076R dyno plot, but dyno plot doesn't tell the whole story - after you've had some time to get acquianted it'll be interesting to see how you find it. Out of interest, with that 11blade wheel does the GTX3071R have the same kind of anti-surge whistle craziness the GT3076Rs do?
*cough* I near sprayed my computer with coffee, my gt3071 sr20 curve is nearly identical, even peak power. I won't post it as i don't want to take away from micks results as that is awesome for a .63 IW on a stock manifold. No boost control issues either which is a relief.
Out of interest, what boost controller do you run mick as i would have thought it would hit full boost a lot sooner (under 3k) based on my old rb25 results.
Sorry, perhaps I should have qualified that with internally gated, ra ra ra GT3071R? :)
I had in my head the typical basic GT3071Rs tend to be between 250-270kw range with full boost around 3500rpm, I've never seen anything to hint they'd be anywhere near getting full boost under 3000rpm! Unless you are running 6psi....
Sorry mate Mick runs a .82
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
