Don't waste your time mick, all you'll be doing is increasing the length of pipe for no noticeable reduction in intake temps.
The air is moving too quickly to pick up much radiant heat off the rocker covers as mentioned above.
As for your leak; if you have any unreinforced rubber joiners then get rid of them. They stretch and allow the air to squeeze out under the hose clamp at high pressure.
I have replaced all the hoses with triple ply reinforced silicone hoses Dave and ive got new hose clamps recommended by yavus they are only bout 8mm wide so they should bite down good on the silicone hoses and since ive replaced the wafer thin alloy pipework with stainless i can nip up the hose clamps that lil bit tighter without crushing the pipe
Haha yeah thats them mate im sure that there is better but they should do the job tho
haha they have gotten you onto the wurth clamps.. I dont mind them but wouldn't call them the 'ducks guts' as they do
SHHHHHWIING! Hahaha thanks Jase just gotta get a longer piece of silicone hose for the boost controller line and put it all back together properly and its zoom zoom time :merli:
lol nice pin, sexy as always :action-smiley-069:
Unreal job on the pipes, looks fantastic! You should make up some rb25 3" metal intake pipes with all the factory connections that bolts up to the factory airbox! Plenty of people like me will buy one. :)
Plenty of people like me can make one. :)
Thanks Harey im planning on making few kits up to sell just need a standard box so i can fab up some pipes
Yeah mate gunna be there Friday arvo sometime gotta call the boys bout lunchtime to see what time Yavuz can finish my tune off their new dyno is due in sometime Friday and cheers its all finished now so come have a chat mate & check my handy work out in the flesh if your floating around
So this will be at Unigroup on Friday? Sweet I'll be there too - have to check out it out in person, looks really good so far!
Yeah they are setting up a new shop in Windsor too which is good for me being a Hawkesbury native :thumbsup:
Oh yeah, I knew that.
I should be out there on Friday also, so It will be good to put a name to a face.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
