Initially I decided to buy a R32 GTR for racing purposes but after spending a few weeks on this site and reading a plethora of 'track builds,' I decided not to track my future 32-R. Basically too many problems with reliability and I plan on having the car for a very long time. So now my intention for my future GTR is more for comfort, touring and perhaps a little showing off during meets.
I want the GTR to be lowered but not crazy lowered. I'm just trying to eliminate space with the tire. I'll probably be running 18" LMGT4s with a 235/35 255/35 tire setup. I would like to increase comfort as opposed to a stiff racing setup. I'm using monoflexs on a Z33 and I love them but a good track car is a terrible street car. My overall goal is to have the ride as comfortable as possible with aftermarket coilovers. I'm not a fan of lowering springs so I'll probably not go that route.
Also, I have my eye on the Nismo suspension kit as I noticed that all the parts use rubber instead of solid steal bushings. Any suggestion on components to accomplish my goal?
https://www.sau.com.au/forums/topic/375423-touring-suspension-setup/
Bilstein shock absorbers are the best for the GT-R. They were developed for the Nissan Racing Team GroupA race cars. Firm, but not teeth chattering. Coupled with a Kings lowered spring, you will have a low, but not too low, ride height. Then upgrade the sway bars for handling. It's a sports car, not a luxury saloon - suspension should be firm, not yank-tank sponge rubber wallowing.
DO NOT run different sized tyres front and rear. If you do, do not come whinging about ATTESSA misbehaving.
  • Like 1
Thanks. LOL, I know I can't expect BMW-type comfort but the main reason why I say 'comfort' is because of my Z33. All the bushings in that car have been replaced with solid bushing and the coilovers are Tein monoflex which are stiff. That car is great on the track but poop on the street. I want aftermarket parts that will feel 'stock' as much as possible.
What do you think about a coilover setup? Shocks and lowering springs are fine but I want the flexibility of changing ride height, etc in the future. I'm looking at the basic tein coilovers. Basically, I'm looking for racing parts that will afford me the opporunity to mess wtih my ride height as well as keeping the ride quality as stock as possible.
you realise that you don't have to convert your car to a full track built car to have some fun every now and then on the track?
Of course, bud. I'll more than likely track it a few times just to check it's handling dynamics but, In all honestly, I've been turned off about racing the GTR. I'll treat more as a daily and/or touring instead.
As fat as you can go - keeping the same size front and rear.
Start with springs 6kg front, 4.5kg rear. Many people will tell you to stay away from Jap dampers if you want good grip. Personally I wouldn't have a clue.
Get some adjustable sway bars to balance the front/rear.
For street, and a lot of hillclimb and targa, a balanced spring-shock setup, with stiff antiroll bars is the way to go. Much better for handling bump-steer, and you get the comfort through the travel of a spring-shock setup. blind_elk is on the money.
People say to stay away from jap dampers? That because those people race their GTR?
I'll probably just grip the 32-R on the track initially to get a feel for the handling but I doubt I'll do much driving and/or racing in 2-3 years.
I'm looking at this package from Nismo:
http://www.rhdjapan.com/nismo-s-tune-suspension-system-stabilizer-set-bnr32-bcnr33-bnr34-56105
I think it fits my cateria of subtley changes from stock yet good handling.
I'll look into blind_elk's advice a little more but, like I said, I don't like using lowering springs... but I've never owned a GTR so who am I to dispute ya'll advice?
BTW, this is going to be an R32.4 that I'll take back to the states with me. Hence, comfort instead of stiffness.
http://cali34.blogspot.com/
It'll planning on buying a silvia or GTS-T that I can mess around with and keep the GTR relatively clean.
If you want comfortable shocks that with a good alignment and sway bars will give good ride height then look at Koni yellows. The Bilsteins will ultimately end up with a sharper handling car, but anyone that runs Bilsteins will tell you they are valved pretty high compared to std or Koni yellows, meaning they give a rougher ride, even with soft springs
Thanks. My buddy bought some Konis for his Civic and they were defective from the factory. I hope that was just an isolated incidence.
Its an oversimplification. Many jap coilovers come with very stiff springs.
I'll probably just grip the 32-R on the track initially to get a feel for the handling but I doubt I'll do much driving and/or racing in 2-3 years. I'm looking at this package from Nismo:
That set looks good. Tein super streets are another option, with similar spring rates.
What you want to stay away from are suspension packages (Chinese, Japanese or any other) that use high spring rates and have adjustable dampers. A good adjustable damper is worth the huge money if:
A: You know what you are adjusting.
B: The adjustability is linear, repeatable and there is little cross talk, ie a that a low speed rebound adjustment doesnt affect anything else for example.
Unfortunately ANY adjustable damper that doesnt cost drug money fails to meet these tests.
So a fixed damper is what you want. In anycase a damper without adjustment can handle a wide range of spring rates. So it is fine. Bilstein do nice dampers by the way. For the money they are excellent.
The spring rates for the Nismo gear are fine for the track and for R compounds and will also do ok on the road. You will need to adjust the camber settings for track work, however.
I see, thanks. I think I have to look at this situation in terms of spring rates first and catelog parts second.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
