Hey.. I'm planning on installing aftermarket bovs (blitz super sound dd) soon but I just wanted to check if installing them on a gtr tuned using a pfc with stock bovs will cause any dramas.
I've heard there could be stalling issues
Anyone with any thoughts/prior experiences?
https://www.sau.com.au/forums/topic/375822-installing-aftermarket-bovs/
I've used an atmo bov with my power fc and i think one issue is that the stock bovs are usually slightly open at idle which avoids turbo shuffling and potentially upsetting afm signals. Mine shuffled a lot when I put the atmo bov on (running the power fc) and had it tight enough to be necessarily closed at idle, plus I had some compressor surge at lower flow rates which really messed with the afm signal and therefore the afr's- I think the stock bovs would have alleviated this. The issues disappeared when I went to map sensor based ecu, and then being able to soften the bov spring to allow it to open at idle got rid of the shuffling. My feeling is that the stockers would be the most trouble free option with afm based ecu.
Edited by doo doo
i like my ppssh sound :)
plus i got a good price so decided to put them on... been driving around with the stockers for a while and I kinda miss the sound... each to their own
thought there would be stalling issues... ill get em put on when the haltech goes on
can the GTR stock BOV be run as atmo?
i got a haltech ecu running map sensor so i wont have issues with the AFM not liking it or stalling.
the blitz BOV i got installed atm is rubbish as i suspect it to be leaking & not holding boost.
ideally i want to upgrade to a HKS SSQV but if a GTR bov can do the job properly that will be the option to go.
Well they leak @ idle/low throttle, so not really... As the air is going through the turbos but not making it to the intake so response would be doughy as a result.
You'd need BOV's that seal always in that situation
Has been done, i think it cost about $50 to do and worked perfectly. The guy who did it was "sh@un"
if its anything like what ive found from searching, they blocked the hole on the base of the bov with a screw or welded it so its sealed.
gonna try tonight by removing the bov and installing a blanking plate, if this improves response i will leave it this way till i get enough coin to buy a HKS one.
i cant be bothered to buy a GTR/GTST bov and mod it as i dont have the time or patience.
dammit blitz, why couldn't they just made a good BOV from factory like HKS!
No Offence Nismoid but you have handled this BOV thread very well, I was actually starting to believe that you hated BOV's and would destroy anyone that had one. I almost wondered if you would offer money for people to send there old BOV's in if they went back to reticulation ( just a thought lol) anyways i had a BOV and have gone back to retic I have now noticed car runs much better down low before boost and spool up time and also keep MIster Plod away as well.
I don't hate BOV's, just a lot of people swap them over and pay the price (poor running etc), and then come back in a few months with another thread about stalling/backfiring or economy etc.
If you go about it the right way however (which means retune, custom work etc), then it's all good.
There just aren't a lot of people willing to do things properly and then complain about the half-baked set-up that results.
It indeed does work perfectly, and will give you the noise you'd expect on gear changes. Personally I started to find said noise very annoying everytime you backed off the throttle slightly when having a go. Pretty sure it didn't make any difference to turbo response between gears in the end anyway.
Obviously, as has been mentioned, you can't do it on cars still running AFM's. MAP based load-sensing only.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
