What a wonderful little event. I had a great and relaxing time and met some really nice people.
Here are a few pics that might make you laugh or at least scratch your heads.
Try this one......... A Mazdza Roadpacer! Any Idea what it is?
I saw a couple over the last 35 years but there were plenty who hadn't.
If it looks familiar it should................. The good old Holden Kingswood was sent over to Japan with no running gear. Mazda fitted a rotary engine, their own gearbox and diff and here it is.
Didn't sell well. Wonder why! :laugh:
  • Replies 148
Absolutely marvelous shots at the end of the day Bob :thumbsup:
5x masterpieces = credit to Owen, Chris, Bob, Simon and Matt (left to right - front shots)
Missing 4x GT-Rs GTR26D, CHU33Y, ****** and KSR.
Thanks Terry....... Not too bad for an Iphone 4.
Bob.
Nice Pics Bob.
Was great to see so many great examples of Japanese cars out there today. I was in awe of both Bobs Aust R32 (so, so clean) and the Brembos on Matts V Spec II Nur!
Also loved seeing the variety of cars, especially some of the original Mazda Rotors, and that diminutive Toyota Sports 800.
Had a great day, but the sun bit me hard!
What a great day! Saw some cars that just made me drool. Bob your 32 GTR is immaculate, just an amazing looking machine. I left early to go and work on my car despite the beating sun, now it's ready to take for rego (I think), shame I couldn't have been one weekend earlier! Was so good, and some great Skylines, as well my mate's Legnum, was cool to see a few of them out in force as well, not to mention the RX-7 with a turbo the size of a house!
Thanks for posting those pics Pauly and Bob. Some nice shots there.
Great day, it was good to meet Chuey, Vlad, Jason, Chris (Bayside blue BNR34 with TE37 SLs), and Alex (PN-Mad) and a few other guys I hadn't met before. Awesome selection of cars.
Thanks to the organisers for a great event. :thumbsup:
A couple more of Bob's:
And the new acquisition!
Edited by God_speed
Only went down for a bit! all i saw was win!!!, so was very worth while! loved every car there today. Had a quick chat to Pauly, your gtt is off tap. When i get my rims on with spacers ill let u know :D. The GTR's were pure S** :D great day!
P.s Danny as if you didnt stay for all that stance!!!!!, (the sexy shots of the skylines at the end :P)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
