100mm from ground to lowest point of the car is the minimum.
Some tester would fail a car with adjustable suspension cos you can adjust the height at any given time.
Pain in the ass really.
  • Replies 61
From what I've heard you can have adjustable suspension aslong as it can't be adjusted below 100mm at the lowest point, so you can put a couple of tack welds on the thread on the coilies to stop the rings being able to be adjusted below that point.
That being said I doubt you would wanna do that to your coilovers.
How are they gonna know if it's below 100mm at the lowest point? They aren't gonna pull off your wheels and adjust it with some forks to find out...
I passed in RWC with coilovers, they aren't illegal, having your car lower than the legal limit is.
where abouts did you get it done if you dont mind me askng? might try out that place
and since when are coilovers illegal modifications? arnt they ment to be better for your car
Apparently, you're not aloud to adjust the ride height.
Fk the coilovers one is a pain in the ass
Pretty sure coils are a no no I passed with coils in having said that
Last time i got dicked was for being too low, spoke to the guy whilst he did the rwc and asked him about adjustable coil overs and how much suspension travel is legal, was told it does not matter if there adjustable and the only rule for travel was that there needs to be some lol, mine is pretty stiff and he had no issues with it, unfortunately he does not do rwc's much any more he just does import compliancing.
And as everyone else stated, getting a dodgey is extremely hard these days, gotta know someone, and if some one does know someone there not passing it onto a random on a forum.
Edited by W0rp3D
umm since when are coilovers illegal? Considering that 'coilovers' is just a fancy name for spring and shock absorbers, sounds a lot like hearsay to me unless someone can prove otherwise.
No mention of coilovers in this document, just keep it at the legal height and you will be fine.
http://www.vicroads.vic.gov.au/NR/rdonlyres/CC48FC10-4D57-4F04-82E1-3BD72EF88340/0/VSI8.pdf
this is from someone who does rwc..
"coilovers are acceptable but there base height ajustability cannot be below minimum clearence ie: 110mm , they also have to have soild tops no camber or castor adjustability is allowed and to top is all off no pillow ball mounts or dampning adjusters... and the spring rates must be to oem standards
lol it pretty much excludes 99.9% of coils"
lol well i failed my roadworthy cause of the coilovers and couple of other little things like pod filter not secured and things like that. didnt make sense to me cause i have a locked diff and they said nothing about that ;/
hmm fair nuff. Majority of skyline coilovers dont have camber, castor or pillow ball mounts however can be adjusted below 100mm. Cant seem to find any documents saying that adjustibility to 100mm is illegal. Just says not to go below it... I'd ask the roadworthy guy to show some documents stating the law regarding coilover suspension...
they're not going to open up your diff housing to find out you have a locked diff.
you can hear it though and feel it when they take it for a test drive lol, i just dropped it off at another place today wish me luck :banana:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
