I did just finish this thread I left a party to go home to read the rest.
All I can say is I have a lot off respect for you I don't even own a skyline I drive a holden vn because I'm holden guy but have a soft spot for skylines so I like reading this form and when I started reading this I couldn't stop please keep posting
Cheers Cameron :)
Scott the guard project was a great success.....it is subtle enough to not "stick out and slap you in the face" and mean enough to "create a stir".
I LOVE IT - just waiting to get the rims out a bit more and I reckon it will look wicked !!
IMO the car is looking the best it has ever done.......
Jez, agree with you that the car is looking better and better. As you've stated that though, the only thing letting in down is the rear fitment. But all things come in time and sounds like your already onto getting it changed. I think if your able to get the rears to fill the entire guard then it will look really good
And put the huge wing back on :-)
Update on the rocker cover project.....this is work in progress and trial and error so be kind ! Also this is the first coat...you have to go over them at least thrice for it to come up nice and vibrant.
Started the other one as the first one cures.....
Getting there.....stay tuned
Update:
Going to go with the current rim setup for the moment but with bolt on spacers at the back so that I can ditch this sunk look asap. Spacers have been ordered and are in the mail.
Saving again for a pair of wider meisters with lower offset and more dish which I will run on the back and swap the rears to the front. Want it to look mean :angry: !!
Got a coilpack cover bit from Jarrad (thanks mate) and gave that a lick of high temp paint. Probably not going to do anything to that and just leave it black or its going to get too "kiddie" with too much colour. I like the way it looks at the moment even though it might seem a tad "quirky" for some. Will give it a penultimate and then a final coat before going over it with clear.
Spacers yes....well it was weird....the "package" was delivered first thing in the morning....I was expecting it so had left the door open with the flyscreen locked...I saw the van pull up and an Asian chick jump out with this mysterious object wrapped in black...she just left it outside the door and shouted "arsehole"...I was walking to the door so basically reached in time to see her rush back to the van having just called me an arsehole with this bomb on my doorstep..LOL
Turns out she must have said "household" and it wasnt a bomb it was my spacers..and she was just in a rush :P
  • Like 1
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
