7 hours ago, GH05T said:
666dan hasnt been supplying through here for years.
i dunno who is the go to guy for that now?
Thanks for the heads up :)
Will keep looking...online is going to have to be the go to option I think !
Dan got back to me and said he isnt supplying anymore. In the meantime I have ordered replacement LEDs online for stop/tail, reverse and indicator so as soon as that arrives I will swap the globes and fit it up.
Keen to see what it looks like on the car.
3 hours ago, GH05T said:
what leds did you go for?
Philips Red Led Brake Light S25 P21/5W 1157 BAY15D 12836 2 Dual Brightness AU
Supercrap wanted $57 for two ! Basically got all four for cheaper than that !
Also got some generic brand ones for indicator and reverse - will update on specs when they rock up.
  • 5 years later...
Brakes are very very good. They dont feel super touchy or sensitive like the feel of brakes on a small lightweight hatch for example (but I have always been a gradual / trail braker anyways so it suits me just fine) and really only start powering on from about 10% in. They are very powerful and bitey from there on though and have impressed me greatly with their ability to pull the car up in what I still visually think would take twice as long (and this is without even stomping down on them in a panic brake).
So overall very impressed with them over stock brakes with upgraded drilled rotors that I ran previously.
I chose the sport pad option from D2 and while they are quite dusty thus far I cannot really frame a judgement on that as I have been braking a hell of a lot of late to "bed them in nicely". So really I have been concentrating a lot more on that in the few drives since installing them and not a true representation of "normal use"
The calipers are huge and only just cleared the insides of my wheels so definitely something to think about when going bigger !
  • Like 1
As far as the coilovers go - in a nutshell chalk and cheese over stock suspension with lowered springs that I was running to date.
The goods
  • handles like it is on rails - would be absolutely fantastic on track as is very very good on smooth(er) sections
  • seemingly less squat when you floor it and grips instantly / the pull feels stronger
  • does not nose dive as much on very heavy braking
  • looks really nice now and sits at a perfect height
The not so goods
  • definitely way bumpier than the aging stock setup which was super comfortable but boat like and very floaty (you do feel every bump and the 16 way dampening setting on the front helps a bit but you still feel the bumps so I just drive with it turned up closer to fully hard anyway. Yet to get to the backs to adjust them (currently set fully hard) as I am looking into extenders that will sit clear of the parcel shelf to allow adjustability without the stuff around
  • my guards cracked during the testing and install sadly but the plan was/is to have them prepped properly and resprayed so I am not too fussed right now
  • Like 4
She looks fantastic!
What do you mean the guards cracked? Did you hit them with the tyres?
I've just put the BC's in my BMW and find them to be so good, even over the Bilsteins I had previously. The adjustment of damping makes them really comfy when wound down too, although I really like firm suspension and I have them at about 2/3rd damping.
  • Thanks 1
Small split / crack on the top of the guard from catching on the tyre(s) sadly yes.
I am actually getting more and more used to the feel of "coilover suspension" with every drive so its actually starting to feel normal 😁
  • Like 1
Cant seem to stop driving at the moment. Loving it 😍
New p zeros make a huge difference and combined with the stopping power and absolutely amazing handling of the coilovers - wow - I am super stoked !
Next project is having the front bar / lip resprayed. Has a fair few stone chips and dings and dents and a noticeable crack / crumple from when the lip crunched on the "low" ramp going up the tyre places hoist which turned out to be not so low :/
  • Like 2
Random pic that I am using as my current screen background.
Sparco carbon foot pedal covers rocked up. Seemingly good quality overall and no blemishes or defects in construction so quite impressed overall. They will need the original pedals to be drilled so I will work out how to remove them and do that as a project over the xmas break.
  • Like 1
1 hour ago, jez NF said:
Ordered a pair of sparco 4 point race harnesses.
should look like this
I just wanted to check that you know about submarining in the event of a collision while wearing a 4 point harness.
I'm not saying don't do it, just that if you choose to do it, at least have it be an informed decision.
  • Like 1
Totally get your concern thanks mate. Just watched this as I didnt really know about it in detail I must admit.
I dont plan on racing or going too crazy so I think I will be fine.
Learnt a few things reading up and watching that video so thanks for alerting me to it cheers 👍
  • Like 1
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
