  • Replies 117
Mindflux,
All the sponsors will be revealed to you all very soon. We have some major sponsors like national chain stores and some smaller guys who deal in performance parts and tuning. All are giving great discounts for members, like fleet prices and min 10% off all these sort of things. All sponsors will be present on the launch day which we are currently trying to organise and you can speak to them personally.
Cheers
Gary
