Read this today and found it interesting
http://www.usatoday.com/news/opinion/editorials/story/2011-09-28/flashing-headlights-free-speech/50593266/1
I know we get caned for it over here if caught doing it, interesting to see its a constitutional RIGHT in the good ole US of A! seems Canada may follow suit, not sure how it stands in the UK but i would be surprised if we moved to anything near as liberal in the next century or two..
Personally i always give oncoming drivers a bit of a flash though i find myself doing it more often when i see drivers at night without their headlights on. This happens nearly everytime i get on the road lately and it seems drivers are generally worse. thats probably a whole nother thread though..
anyway has anyone been busted for flashing drivers? I held up a sign once on crown street warning of a speed trap, only lived down the road so it wasnt a big deal. Got lots of thumbs up and a few friendly toots, wouldnt try anything that brazen now though..
https://www.sau.com.au/forums/topic/378723-do-you-warn-oncoming-drivers/
  • Replies 134
Of course, unless theyre in some expensive euro car. Whoops.
When the popo are around I dont flash the h beams I turn my lights on and off, never been pulled up for that either.
^ you would have time to tell?
well say you're down a stretch of the road thats 200-300m long. if you see the car coming from the other direction flying along, then I should think one would have time to tell if he/she is speeding excessively or not.
mind you this would be based on the fact that they havent been warned by other drivers.
Good stuff! the karma will come back to you in the form of a free beer or $2 coin found under the couch one day :P
as for the rare situation where you will clock that the oncoming driver is flying along at an excessive rate and there are no cars in front or behind you to also warn him I would be flashing those high beams like i was having a severe epileptic fit (unless it was a euro car) but I understand where your coming from and respect that.
I don't see why we should be breaking the law when informing oncoming drivers of a speed trap.
The radio is forever announcing where the locations of present multanovas and handhelds are.
What's the difference?
Aside from that, yes, I ALWAYS flash oncoming drivers a warning when applicable.
i don't. the way i see it is that there are too many morons on the road that casually speed where ever they go. many of them could do with a bit of a wake up call.
i actually randomly flash people when there is no speed camera. makes them slow down, LOL.
Oncoming Drivers:-
Drunks see the flash too late
P1s swerve to avoid the flash
Narcissists think you're coming onto them
Druggies think, "What was that?"
Manic ppl go faster
Grannies go slower
Cops are vengeful
No I don't flash. Never know who you're going to meet up with these days ;)
I do always have and always will.. Our finer law enforcement officers get a good enough Xmas party out of some of us car enthusiasts who may have the slightly too low or loud car that has been labeled a hoon without even driving anywhere just beacuse of the car you drive.
say flash away. Just be careful who ya flash as they drive some pretty uniqe cars these days lol..
I've noticed it too. I'm thinking it's something to do with a lot of cars these days, have the dash lit up with the lights on or off. Ie, dash is on in the daytime as it works regardless of headlight switch position.
So if the numpties forget to turn their switch to 'auto', or 'on', then no headlights! They only notice when they are not behind another car and there are no street lights at all, dumb asses!
-1 for being Un Australian
+1 for In real life trolling
so you come out even i guess, GTRsean your theory sounds about right. Not driven a car that was less than 15 years old though so im not sure whats going on with all these new fangled jalopies running around..scary stuff.>_<
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
