Interesting concept.
Nissan is working on a project based around shoehorning the mighty GT-R drivetrain into the body of a Juke crossover.
One might wonder why Nissan would go to such great lengths to pull off such a feat, but for the Japanese automaker and its engineers the reason is simple: to drum up excitement and gauge potential customer interest in a sportier variant of the Juke.
The Frankenstein-esque car, going by the name 2011 Nissan Juke-R Concept, is strictly a design study and any production version is unlikely to feature the GT-R’s ballistic twin-turbocharged V-6.
To accommodate GT-R running gear, which has a shorter but wider overall front print than the Juke, engineers needed to add flared wheel arches, revised front and rear bumpers, and a unique split rear wing.
Under the hood is a 2011 Nissan GT-R’s V-6, which means output is capped at 480 horsepower rather than at 523 horsepower like in the newer 2012 model. Nevertheless, the concept should still offer insane performance figures, especially considering that its stripped interior will mean it’s lighter than the GT-R.
Under the boot floor hides the six-speed dual clutch transaxle, with the front and rear ends joined by a modified GT-R 4WD driveline and prop shaft. Chunky 20-inch RAYS forged alloys complete the transformation.
The Juke-R Concept is currently being developed in the UK by motorsports engineering firm RML with input from the Nissan Technology Center for Europe. It is expected to complete its first tests this November and be fully road-legal.
http://www.foxnews.com/leisure/2011/10/04/nissan-combines-gt-r-and-juke-to-create-super-cute-ute/
More info and pics here: http://www.fastmotoring.com/index.php/2011/10/nissan-juke-r-with-480bhp-3-8-litre-twin-turbo-v6-engine-from-gt-r/
https://www.sau.com.au/forums/topic/379168-nissan-juke-2011-gtr-juke-r/
Looks like a Munaro with a touch of GT-R at the front and 370Z on the rear biggrin.gif
Redesign the front lights/bumper, lose the spoilers, touch up the ass where to make it less boxy and I think it has some real potential IMHO :P
Edited by Converge
I agree, it looks like a Murano cross between 370z. I'll bet it's being positioned to be a Porsche Cayenne rival.
I don't hate it.
i'd use it to tow my trailer queen skyline around, in the ideal world. Not with green rims maybe, some gold TE-37's possibly, dumped it looks ok. Ugly as sin but ok if that makes any sense.
I bet some sheik in Dubai ends up buying the one off concept they actually make, just like that 11million euro 300km/hr bus they just built in Holland..
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
