Yeah, I still have all the software to tune it, so might take it for a tune to release a few ponies. However I can't justify it with the stock cats in place. So I'm caught in a catch 22. Don't want to spend on cats, but can't progress without them. A baby capsule will be the next mod, sometime in mid November.
The 180 is defiantly satisfying my need for speed and track time better than the stages. Good decision.
Was the Emo white? Yeah, dunno. people have mixes of hot and cool down laps. Fast cars does not equal fast driver. Was a fun day. Wish I went faster. Massive oversteer moment on my 1:10.6 lap...
ha... as i said, I was stuck in traffic the whole time, and as soon as i cleared ready to pass down the straight, I blew an IC hose off, and fouled the plugs. So not the most entertaining viewing....
  • 2 months later...
Hello old Thread!
Well, some updates. The Stagea got a full paint correction and detail by a workmate of mine, who does detailing as a part time job. Looks amazing. I was there helping out, and the levels that he went to blew my mind. Was a full day for the two of us, finishing about 5:30 in the arvo. The paintwork was brought right back down to the clear, APC washed, decontaminated with 2 methods (clay and ironX), and polished using a Sonax product and RO machines. A sealant was applied, and to finish it off, a wax. The awesome news is that when we checked the paint out with a micrometer, the paint thickness is consistent with factory paint all around the car. So that means it has never had a panel re-sprayed. A nice feeling to know. So here is a pic in all her glory on the recent Sydney Stagea Cruise.
Now quite a few things have been going on with the 180sex too. I had terrible understeer issues at wakefield the last time I went out, so I set about improving this, and adding in some extra bits, and improving reliability.
On the track, I had a turn where the power cut out, and I got swamped coming out. The motor cut out all together, and then re-started. When I got back to the pits, we had a look in the bay and saw that part of the Loom travelling down the passenger side of the car had got rather toasty. After the track day, I re-wrapped the loom, and then wrapped it up in protective heat tape. Should be fine now.
I bought a second hand Greddy Profec B Spec II boost controller. I wanted some adjust-ability to the power levels so I could learn to drive it better on the track. I wired/plumbed this in before we went on holidays and booked a Dyno date with Jez to get it setup. I hate electronics, but honestly it wasn't that hard, just crawling round under the bloody dash was a right PITA!
So, back from holidays, and off to Jez. Since it was running a boost Tee, and I never touched it, I had no idea what gate pressure was. Turns out its 10psi... hahahah. Anyway, a morning on the dyno saw the unit set up, and the mapping reconfigured to run in the low end of the map too. So now I have 3 power levels - 230kw @10psi, 270kw@16psi, and 289kw@18psi. So good result. We tried to push a little more boost, but have pretty much reached the limit of a track tune 98 oct fuel. If I want more, then e85 is the way forward. Doesn't bother me too much, as it has plenty of power.
I got home, and the rear end of the car was bugging me. There has been a knock somewhere in there for a while, and I just wanted to get everything checked over. So I dropped the rear subframe out the next day. Checking over the bushes, everything was fine, unis and shafts fine. So I popped the diff out and got Award Gearbox and Diff at Seven Hills to check it out. This gave me time to degrease and clean up the subframe. It was annoying me how dirty it was, so I pressure washed it clean! Turns out the Diff was in great condition, so they sealed it back up, and gave it back. Good insurance to know. Didn't get a picture of this unfortunately. Reinstalled the subframe, bled the brakes, and while the diff is still noisy (this is normal for the type of diff), whatever clonk was there before was gone !
Now, with the 4 point cage, the rear of the car was quite stiff, but the front was not as rigid as I'd hoped. This manifested itself in the front end being a bit hard to handle on the track. So some Stiff was in order! I couldn't fit the Tomei 3 way strut tower brace because it fouled the turbo, so I went looking for a CA18 unit - Found and bought a Cusco Steel unit on the eGhey. Fits up good, should do the job well.
Then I got recommended the Nismo power brace, which is basically the equilviant of a strut brace for the power part of the suspension. This ties the quite flexible front arms together and boxes them. Thought it would be a good addition, and who can resist some Nismo part whoring! So I'm installing that today :)
This came from RHDJapan... slower than expected, but I got a Nismo Sticker that's going on the M35
Last, I got some cheap Bridgestone RE55S semis to try out instead of the R888s on the front. They were quite hard, but still had some life left in them. Mounted them up on the track wheels, and put them on the rear of the 180 to ***ahem*** clean the up a little. After the surface layer was taken off I removed them, and treated them with Grip tyre softener. Pretty awesome stuff. Stinks to high heaven, but works well. They sucked up the mixture, and feel much better. They are now curing before the track day which is late October.
Also ordered a new Radiator hose, as mine had cracked internally and was slowly leaking, and some adjustable upper rear camber arms, hopefully to take some of the neg camber out of the rear for a bigger contact patch.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
