  • Replies 128
Cheers Madaz, will have a look at that, opened up the afm and one of the connections looks dodgy so will solder that one as well as all the other connections and see if that fixes the problem. only car I have to drive at the moment so really hope its not detonation, especially a month after I spend 3500 on the bloody thing.
ahh ok, no, none of that, just feels like there's no fuel getting to the motor and stutters.
But yeah, borrowing a soldering iron from a mate on Saturday, i'll let you know if it fixes the problem.
  • 10 months later...
Okay...I need some help please!
I recent bought a OS Giken Twin Plate TS2CD second hand, it was recently rebuilt about 5000kms ago and came out of an early R32 GTR. I spoke to Otomoto who happens to be the OS Giken distributor in Australia, and they suggest I get a 12mm Sleeve release Bearing...which I did. I have had the clutch installed just the other day, and a few issues have arisen.
The clutch doesn't seem to engage/disengage correctly, you can have your foot on the clutch, try and put it in first (while the engine is running) and most of the time the car will begin to creep forward (if the brake is off) but not go into gear, same can be said for reverse, and really any other gear. Sometimes it will go in, but it goes in with a bit of force not freely like it should. Sometimes when either driving, or trying to put it in gear to take off, it will crunch/grind as it goes in. Quite often when going for 4th or 5th, it will sound like you are trying to put it into reverse while driving, or even down shifting or up shifting you go for another gear, and it just won't go in.
What can I do to fix it!?...other then buying another Clutch.
Other info:
12mm Release Sleeve Bearing
Push Rod has been shortened
Stock Slave Cylinder
Braided Clutch Line
Clutch Pedal has been adjusted inside the cabin
Get the other size bearing as there is a pre 96 one
You will have to take it out and either compare with you old bearing or just take it to Nissan and get them to bring both out and buy.the one you don't have, this happened on my car
The pilot bearing in the back of the crank is the wrong one or stuffed not allowing freespin( frozen up)
Or pressure plates are locking up together the clutch runout is wrong , which hangs up the release bearing
All require removal
Or air pocket in slave cylinder braided nismo lines are a bugger first go round to get all the air out
Hmm, Ok I will have to have a look into it, I think I was using something like a 24mm bearing before as it was apparently a big difference between the sizes.
All require removal
The bearing in the crank shouldn't matter, as it wasn't replaced and was working before...unless something happened on install.
There shouldn't be an airpocket as we did bleed it for awhile with no air bubbles coming out.
It does matter Abe, if its stuffed it will do exactly as described ( past experiences of a broken bearing)if its not aligned as Luke said it kills it to pull the case together with bolts ??
Another issue is the disks if one is installed backwards that can do some odd things as it eats its way thru the pressure plates but that makes a bucket load of noise and death to the clutch is rapid
On 34 the braided hose goes into a little metal bleed /fitting deal and unless you hold it just right while bleeding it ,it puts the release point to close to the floor , not sure if the 33 has that as well about half way down from master cyl??
I have a dilemma, we are stuck in Canberra with our V35, with an issue that nobody can seem to diagnose and we have searched on the internet via google and the car trouble website with no such luck. So thought we would try here.
We drove the V35 - CVT to Canberra with no issues whatsoever, the car was an absolute dream. Arrived in Canberra and two days later the car seemed to go into "failsafe" mode ie stuck in first gear when driving. This was happening every time we drove it and so when it happened when first driving the car we went straight back to where we are staying so as not to drive it a long distance.
We saw a mechanic the day after it happened and they did get the error code and cleared this and the car drove fine for a short amount of time. The issue of being stuck in first gear happened again. We sourced the IPS sensors from Melbourne to change these over (as the failsafe issue happened in the past and this fixed the problem).
When driving to go and get these replaced - after nursing the car for a km or 2 driving at 40km so as not to over rev the car, she started changing gears and purring like the kitten she is. We changed the sensors and the problem persisted, we drove out to a friends workshop with a scan tool and the problem happened intermittently when first driving the car, but the scan tool was not able to read the issue at all. The mechanic who could read the issue is now closed until mid January and we are due back to SA well before then.
Do you guys have any idea as to what could possibly be the issue? We have spoken on the phone to the guys at Import Revolution in Melbourne, they are saying that it could be the solenoid in the CVT, which would mean dropping all the fluid out, changing the solenoid and replacing all the fluid in the gearbox (costing thousands) or it could be the fact that the wrong fluid has been put in the CVT in the past (this I dont think is possible as we changed the fluid completely about 3000kms ago and the fluid in there was still the original fluid with no issues at all) or the fluid could possibly be a little low - this we are checking today.
We are wracking our heads and it is driving us a little batty, we would like to try all other options before dropping all of the liquid gold out of the car. I know that not many of you know the V35 and loath the CVT but, thought we would try our luck.
  • 4 weeks later...
Please help with advice....
Stagea rb25det wouldn't start this morning.
Cleaned afm, afm connector & coilpack loom connector, and cleaned battery terminals. Checked fuel was getting to the fuelline.
Car started but stopped when I shut the door or bonnet. Also stopped without closing door or bonnet after a minute.
Found blown 7.5v ecu fuse under dash & replaced, but this hasn't fixed anything....
Replaced the old broken & dodgy positive battery connector & had immediate success. Car started nicely. Yay.
Car started, but shuts down when coming to a halt. Shut down at end of driveway, end of road, and when going slowly over a spoon drain.
Adjusted Idle control screw all the way out but didn't make a difference to the idle rpm.
What else do I try / clean? Serviced the car a few weeks ago but didn't change fuel filter as I find it hard to get to. Will try to replace when engine cools down later. Any suggestions are welcomed!!!
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
